Hi, I have 1 stored code P0856 Traction Control Input Signal Error, what could be causing this?![]()
p0856....Traction Control Input Signal
goodluck mate
That Bad Aye??
could be from, how the traction control turns off for 1 sec and comes back on.
a few ppl have had this
It sounds one worse than P0855...
Never argue with idiots. They will only bring you down to their level, then beat you with experience.
Going from memory.......
Diagnostic Trouble Code Description:
Traction Control Torque Request Signal Message Counter Incorrect
Possible Sensor Faults
ECM
Possible Related Diagnostic Trouble Codes
DTC P0856
Circuit / System Description
The electronic brake control module (EBCM) and the engine control module (ECM) simultaneously control the traction control. The EBCM sends a serial data message to the ECM requesting torque reduction. When certain ECM DTCs are set, the ECM will not be able to perform the torque reduction for traction control. A serial data message is sent to the EBCM indicating that traction control is not allowed.
If you wanted any more information on Diagnostic Trouble Codes, use this search engine.
(You might need to be a registered user though... Not too sure)
www.carmodder.com • Search Diagnostic Trouble Codes
