Results 1 to 12 of 12
Thread: how to suspension
    astroham is offline PHATV6
    SIDI sv6
    Jan 2010
    Penrith
    Default how to suspension
    Hi all ... i have searched the how to section and cant find anything ... i have some springs, shocks, front and rear sway bars, front strut brace, and some bushes ... does anyone know if there is a thread on how to do this?
    TI3VOM's Avatar
    TI3VOM is offline VT V6 wanting 300RWHP
    VT V6 Acclaime S1
    Feb 2009
    Somewhere
    On how to do what exactly?
    VT V6 fitted with DMS gold 40mm coilovers, Whiteline adjustable swaybars & strut brace, 330mm AP racing brakes, Rebuilt 3.45:1 LSD and a Powerdyne supercharger
    Check it out: http://forums.justcommodores.com.au/...-v6-racer.html
    B3nj's Avatar
    B3nj is offline they see me trollin
    '09 VE Omega
    Sep 2010
    Knoxfield
    VE SV6 SERIES 2
    Jun 2011
    Kearns
    Quote Originally Posted by B3nj View Post
    ^^^ how to suspension!! lol
    Make a sculpture maybe
    SIDI sv6
    Jan 2010
    Penrith
    lol fair enough ... it was late and i was tired ... how to install new shocks springs swaybars bushes and strut braces
    Troy711's Avatar
    Troy711 is offline Moderator Puppeh
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    Apparently front sway bars are an absolute bastard to install. Also, depending on what bushes you bought you may need a press to get them in.
    VE SV6 MY10 SIDI Sportwagon
    Sep 2011
    easy: Put them into the boot of your car and drive down to a suspension specialist, fork out $400 and get it done by the pros.......
    SIDI sv6
    Jan 2010
    Penrith
    600 plus wheel alignement is the best price i have been quoted ... and its only front springs
    Evoke VE HSV GTS 6.0 auto, XR6 turbo ute.
    Aug 2011
    Mount Gambier, SA
    Thats what happens when you live in Sydney. You have to pay for the rich peoples houses
    Still worth paying someone who knows what they are doing.
    2010 ve sv6 Ute
    Feb 2010
    Out of interest how much would a set of sway bars be for a ute be fitted??
    UFO's Avatar
    UFO
    UFO is offline I Believe
    MY10 VE Sportwagon SIDI 3L
    Oct 2009
    Quote Originally Posted by astroham View Post
    keep ringing around mate, that's rediculously expensive. I got pedders sportsryder springs supplied and fitted with wheel alignment for $600.
    to be honest its not worth the trouble trying to do it yourself. get pro's to do it.... faster, cheaper, and you know it will be done better than some rookie in a home garage stuffing things up.
    allow $50 a corner to change springs, then because springs are already off another $20 a corner to change shocks over. that's $280.
    forget about the strut brace.... its a wank factor addon that will do nothing for your VE, because the chassis is already stiff enough.
    as already said sway bars and bushes are incredibly hard to install, let alone install correctly. you set the wrong tension and you'll stuff up your suspension geometry. I'd allow another $300 to get front and rear bars installed along with new bushes.
    then a wheel alignment
    so $600-700 in labour should do it... and I'm sure if you called around you'd find a workshop to do a cashy for you.
    you dont stuff around with brakes, and you dont stuff around with suspension unless you know EXACTLY what you are doing.
    SIDI sv6
    Jan 2010
    Penrith
    sorry about the misunderstanding ... its only front springs going in not all four ... and for everything its 600 installed then another 95 for the alignment ... so i guess its not to bad a price
  1. Sedan Suspension to wagon suspension
    By BADNWS in forum VE Holden Commodore (2006 - ?)
    Last Post: 07-05-2011, 05:01 PM
  2. Fe3 suspension in a vy?
    By smi5575 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 03-04-2010, 08:38 PM
  3. Air suspension for my VY
    By eclipz in forum VY Holden Commodore (2002 - 2004)
    Last Post: 03-03-2009, 06:19 PM
  4. suspension
    By oOSparkyOo in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-01-2009, 12:11 PM
  5. suspension
    By havick vk in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 20-12-2008, 05:33 PM
