hi guys im new here
i replaced this joint on the car because of vibration from the tailshaft, once i replaced it the car ran beautiful, til today which is only 3 weeks later the vibration has returned, does anyone know why? is there a stronger one i can buy?
i have done a bit of research and have had no luck
thank you in advanced cheers ben
This is a weird problem.
If replacing the insulator donut made a difference, then all I can think of is that your tailshaft balance is out (or thrown a weight) that working on the donut until it weakens.
VE II SS-V Sportwagon
Who replaced the Uni joint? Because these tailshafts were designed with non replaceable joint If the new joint wasn't crimped in to keep it perfectly central theres a chance that could give you a balance issue.
The other thing is the center sliding joint. The splines have been known to wear out with fairly low k's particularly on manual models and that can give a fair vibration in the driveline
