Results 1 to 6 of 6
Thread: Front driver side indicator bulb access
    VE SV6, VE SSV
    Feb 2009
    Default Front driver side indicator bulb access
    HTF are you supposed to replace the front DS indicator bulb without pulling the light assembly out? Unfortunately I am not a double jointed elf with hands the size of a baby - my normal man sized mitts cannot reach deep enough to even touch the indicator bulb cover, let alone grab/twist/remove it. I've removed the coolant reservoir filler tube, but still no go. Between the looms and small access holes in the front right corner of the car, I can't see how to reach it. Is there a trick I am missing? Jack the car up and remove the wheel and plastic inner guard shield? Am I just thick and have missed something really simple???
    B3nj's Avatar
    B3nj is offline they see me trollin
    '09 VE Omega
    Sep 2010
    Knoxfield
    The side indicators slide out I think I read somewhere here. you dont have to do it from the inside.
    B3nj's Avatar
    '09 VE Omega
    Sep 2010
    Knoxfield
    VE SV6, VE SSV
    Feb 2009
    2008 VE SSV & 1999 VT SS
    Jul 2009
    This one is no fun. Been there recently.
    If you remove the dust cover (twist and turn) off the headlights, you'll have a bit more space to work in.
    Front wheel drive cars are the work of the Devil.
    VE SS-V
    Jun 2005
    Quote Originally Posted by GKW View Post
    Agreed. I had the same problem, and that made the difference between being able to get my hand in and not. I would like to emphasise one little helpful hint from the owners manual -"Note: Take care not to drop the dust cap into the engine compartment". I was reciting all the way through "dont drop the dust cap, dont drop the dust cap, dont drop the ... D'OH!"
    I fished around with a coat hanger for ages, before I gave up and had to remove enough of the wheel arch trim to be able to retrieve it. Not recommended!
  1. [VIC] WTB: VT S2 driver side front gaurd..
    By padrickz88 in forum Swap / Wanted to Buy / Trade
    Last Post: 18-07-2011, 12:40 AM
  2. front driver-side tyre wear
    By D-Man in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-07-2009, 01:31 PM
  3. Replacing front right indicator bulb, Help thanks
    By ac2026 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-11-2008, 09:51 PM
  4. Vp Calais Parts, Front Driver Side Door and Front Quarter Panel
    By coops_23 in forum Swap / Wanted to Buy / Trade
    Last Post: 16-05-2008, 09:34 PM
  5. help! changing front left indicator bulb
    By weedo_86 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-12-2007, 04:23 PM
