Results 1 to 5 of 5
Thread: Ve v rough transmission??
    VX acclaim S2
    Oct 2009
    Default Ve v rough transmission??
    Any experience the 4 speed transmission being rough n clunking through gears, mainly from first to second and second to third under light acceleration. Giving a slight clunk when changing....??? Anyone else experiences this? Car has done 120.000 km
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    They are a older design and did get a name for being a bit rough compared to the five speeds, has it always done it?
    VR v6
    Jan 2011
    perth
    Assuming the fluid level's right...pays to double check. Shouldn't really clunk if its ok, maybe only slightly
    VX acclaim S2
    Oct 2009
    Fluid level is fine, and it is very slightly, some people dont mention it, but I am a mechanic and have been grown to become picky, as some iv done need valve bodys and electro plates to make them perfect, I might do an auto service and see if It gets better
    colourmesilver's Avatar
    colourmesilver is offline 08 Omega
    08 Omega
    Jul 2011
    them trans never reseal properly, and they clunk and hold every now and again
  1. VN V8 Rough ldle, Rough Revving and slight backfire
    By seabs in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-08-2011, 10:43 AM
  2. HELP Engine Light / Transmission light and rough gear changes
    By flash20005 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-10-2010, 03:34 PM
  3. Rough idle, Rough take off and rough stop.
    By Niggadore in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-06-2010, 05:49 PM
  4. Vn - Rough start & Rough Running Below 2k
    By ghog1726 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-03-2009, 10:02 PM
  5. VL Auto Transmission - Rough downshift from Overdrive
    By grazm in forum VL Holden Commodore (1986 - 1988)
    Last Post: 10-08-2008, 12:31 AM
