Hi,
I would like to change the pollen filter on my VE Berlina and I am not where it is located and would appreciate any advice. Also what are the steps required to change the pollen filter?
Thanks,
Lift up the passenger side plenum chamber (7 or so scrivets) then just pull it out
Originally Posted by Reaper:
Originally Posted by Jecs:
Do a quick search on here and also the G8board in the States and you'll fin directions and pictures to help.
Front wheel drive cars are the work of the Devil.
or just go buy the new filter from holden and it comes with instructions.
How much is a pollen filter? I reckon mine hasn't been replaced for about 2 years.
If it's anything like Subaru, they wanted $75 for a paper filter that would probably cost about 50c to make.... it that. Paper element, thin flexible plastic frame. Then you have to fit it yourself.
I suffer from hayfever every now and again, but I'd rather just pop a pill than give away that much money for nothing.
Edited: Just googled and came up with this result from this very forum discussing fitting instructions.... Cabin Filter
$35 for a Repco one.... now that's a little more reasonable!
Are they washable?? On my Soarer, I just got the missus to wash them, and they came up OK.
Thanks Troy. Just to confirm did you also need to put back the leaf filter/mesh after replacing the pollen filter?
filter replaces the mesh, and its a PITA to fit
The Mad Dutchman
VEs dont have pollen filters unless optioned, just a leaf filter and yes they replace the leaf filter so you can throw it away.
No you cant wash them it greatly reduces the filtering ability if it even survives the wash.
Silver Certified.
After reading this thread I had no idea these didn't come standard, so went out and got one from watsons holden for $35. Took 10min to fit up
Hey Ricey, do the VY's have these? I've read about VT or something but I can't work out how and where it is on the VY.
No unfortunately pre VEs dont have them.. Ive seen a thread where you can dodge one up but theres no proper slot for one.
Silver Certified.
Was probably trying to fit an air filter in the pollen filter slot hehe.
Silver Certified.
its a pain in the arse if you have big hands.
The Mad Dutchman
I went the cheap option and bought a $20 filter from autopro, and it really didn't fit well at all. Was about 5mm too big at a guess. However, it beats paying $90 bucks on top of my service for Holden to do a routine job for then, that would likely take 10 minutes.
what are the advantages?
