hi guys i have a 2007 V6 3.6L omega sedan and ive been filling it right up and setting my trip and everytime it gets low on fuel
ive only driven just over 300kms i dont drive hard but i do up it sumtimesholden said i should get 11L per 100kms but on the
fuel consumption reading on my car it always sits at 17L is there a reason for this and is there sumway i can make it better
They tend to drink alot but check o2 sensors could cause more fuel consumtion. How many ks has it done
95,000 ive got a vt aswell what I get 600 to the tank just seems like it gets really thirsty even when im drivin like a granny
I think that is pretty high, what type of driving do you do? CBD? highway?
Check out my VE Commodore My Omega Mods
### me...you may as well get a V8...you will get better milage
fark thats high, not right at all. definitely get it checked out.
Def not right, I get more than that in the v8 barge
I think you need to look at your driving style for your conditions. Oxy sensors do play a role but not that much. Smooth driving is the key. Lighten up on your right foot and you'll notice a difference. Its a heavy car that needs a whoof to get it going but you don't need to be the pack leader all the time.
Around 13ltr/100K's is the average consumption in traffic.
All that said doesn't mean everything mechanically is working properly and could be contributing some-what. Make sure your service and tune is up to date and your tyres are inflated, etc.
VE II SS-V Sportwagon
as already said, something not right... that's very low fuel economy.
depending on how you drive, should be almost double that.
wow that was alot of replys really fast thanks guys um I live vbin nowra in the south coast so theres sum highway driving and a small cbd that im in everyday I just had it serviced and it isnt due for another untill 105,000km ive been pritty light on the pedel ive just been used the normal unleaded I just thought if I can get 600km out of a tank in my vt I should get at least the same out of this even no its a 3.6 pushin a little more weight
and check your wheel alignment...
I have a Sv6 sidi and do a mixture of highway 80kmph driving and 60kmph town driving and my fuel light has just come on at 780kms travelled at 8.9l per 100kms. Id say something is not right with your car at all!!
To the OP.
Commas and full stops would be appreciated.
No Replacement for Displacement
sorry bud im pretty bad at writing. Phantom6 I do the same driving as you 50k and 80k zones and drive about 3ks to work everyday. Mines not sidi but I think I should get 600ks out of my tank I might drop past holden tomoz I cant find anything about a common problem online beside what yous have writin and if a v8 can get more to the tank i must have a problem
Something not quite right there, im getting 13.8l per 100km out of the V8 just normal driving.
I can get as low as 10.9L with my VS Grange, that VE has some problems
Johnny_boi, those figures are bad if you drive as described. I have really improved my 70K 3.6 Alloytec consumption by doing the following...... maybe you could try some of these steps.
1) Reset the fuel measurement system (don't know how, but had it done on mine)
2) Tyre Pressures increased from 36 to 40 psi (20" tyres)
3) Wheel alignment
4) Replaced air cleaner element with new holden one & then went for a K & N panel
5) Changed to 98 RON BP Ultimate Fuel
6) Cleaned throttle body
Even at this point I still had fuel consumption of 14.9 l/100km while driving like a grandad around town & a really poor throttle response. If I accelerated I would get little or no response at first, then with a tiny bit more throttle the thing was way too fired up & resulted in it being impossible to drive smoothly.
7) So then I replaced the old Bosch spark plugs with NGK LTR6A-11 or LTR6AP-11. I am pretty sure it was the first number although the AP-11's are listed also for the Alloytech V6
Well to the results.... Much smoother idle - Can't believe the smooth throttle response - Car is sooooo much nicer to drive - and the clincher for me was the 14.9 figure dropped immediately to 13.2 within the first 33kms of my first tank of gas with an average speed of 31.2 kph.
The range figure on the dash has never read over 510 kms, when driving around town, ever since I've had it but now reads 650 kms.
Finally a decent result & although the plugs have only been in for a few days things look promising.
The downside to changing plugs is the need to remove the intake manifold or part thereof (upper) I think. I was going to do this myself but thought better of it. So it was quite a costly excercise. My VE being an 06 Series 1 car, meant I had to replace the shitty paper manifold gaskets with the aliminium ones @ $130. Add the cost of spark plugs plus I paid $60 labour to have the job done. Hopefully it will pay for itself over time.
Hope this helps
See my current ride here - http://forums.justcommodores.com.au/...-calais-v.html
See my old ride here - http://forums.justcommodores.com.au/...calais-v6.html
Should have got a maniflold insulator from MACE for $150.
I just finished with my first full fill up on my car and got 416km/s out of the tank. With an average of 14.01L/100k.
This was mainly town driving with about 80kms of highway driving. I used Vortex 98 to fill up and was a mix of average driving like a granny and the usual young person driving.
So overall, I think I'm pretty happy with it, considering that tank lasted me just over a week. Probably would have lasted longer if my holidays didn't start 4 days ago, would have done less driving because I would have been at work
P.S. 2008 VE SV6.
Reading these posts makes me feel good that i bought a SS over a SV6 (sooo close)
where do you fill up in nowra? maybe the fuel is not the best. i go there every day and get ~9.5l/100 and mines got 180K km on the clock so a bit worn but I do the highway from the gong and back everyday so it not just a flat straight run but I get at least 750km from a tank. I would be freaking out with that economy as its bad enough spending $130 a week on fuel. i stay away from the all e10 and 91ron unleaded and absolutely stay away from the cheap ethanol place on kinghorne up near the trevi as these all give me poor fuel economy no matter how heavy my right foot is.
na i fill up at caltex in southy i filled up with vortex98 today and reset my trip so we will see how this tank goes. If theres no difference i will try changing (sparks plugs, 02sensors, fillters ect.) and check my wheel alginment and tyre pressures. Womble66 what modle is yours is it sidi cause thats heaps good fuel range even no your doing mainly highway driving will have to take it on a trip to sydney and back soon to see how it goes on he highway. I will let you no how it goes after this tank and like i said if it makes no differnce i will change sum stuff. I got told that if you disconoct your battery and leave it over night your comp will reset by it self.
We have a SV6 with around 116,000k`s I get about 9.8-10.0L/100 round town.
We`ve also just gotten back from our week up at Surfers.Car fully loaded 2 Adults,1 kid,boot zero room,Roof box that takes up whole roof and we still managed to average 9.2L
Should also add we only fill up with plain unleaded or the Bio fuel .Tank range round town in 560-580 depending how hard I go.I used a couple tanks of 95ron when we first got it and it made no noticable diffrent driving.Even towing our loaded enclosed motobike trailer no pinging but fuel usage does go up to 12-12.5L
