Results 1 to 22 of 22
Like Tree8Likes
  • 2 Post By LittleMissVE
  • 1 Post By BigBoss
  • 1 Post By Supe
  • 3 Post By LittleMissVE
  • 1 Post By Fu Manchu
Thread: Grinding/scraping sound when reversing?
    VE Clubsport
    Mar 2010
    Middle of Nowhere - WA
    Default Grinding/scraping sound when reversing?
    I don't post in here as often as most (or as I should), mainly because compared to majority of users I don't know a hell of a lot about the workings of commodore's... ANYHOW... I have a problem.
    My VE, for the last month, in the mornings (when it's cold) when I reverse, I get a TERRIBLE grinding/scraping sound. I am going to take it to the mechanic & get him to check out what's going on, but it's more just getting the time to get there. I probably should have tried to have a look underneath, but, well, I'm a girl.. I'm not getting on my knees.. Well not to look underneath my car anyhow... And I've got no idea what I'm looking at anyhow.
    Has anyone ever had an issue like this? Reason I'm asking if anyone knows anything about it, then I can get an idea of how much work I need to get done & how long I won't have my car for....
    TinSnips's Avatar
    TinSnips is offline Polish all the things...
    VE SS Ute M6
    Mar 2010
    Hills District, Sydney
    Can you narrow down where on the car the sound is coming from? Front, back, driver's or passenger's side? It really could be anything from a mechanical fault to the neighbour's cat stuck under there at this stage. Is it a metal-on-concrete sound like something has fallen down or a mechanical grind?
    VE Clubsport
    Mar 2010
    I had a listen this morning - it sounds like it's coming from the front end of the car... I can't really pin point if it's the driver side or passenger though, sorry. Hopefully that helps
    VE Omega
    Nov 2010
    Haha, probably your best bet is to stop by your mechanics for like 5mins and get them to have a quick look at what is going on.
    Check out my VE Commodore My Omega Mods
    Supe's Avatar
    Supe is offline Supe
    VE Calais 6.0
    Jan 2008
    Rural NSW
    Probably rocks stuck in the brakes and you only notice it in reverse because it slow
    2011 SV6
    Apr 2011
    I have a similar issue, golden thinks it's my abs self leveling test, apparently some cars are louder than others.
    VE Clubsport
    Mar 2010
    Quote Originally Posted by Darks View Post
    Oooh dear... Thinking maybe the amount of peroxide from the hairdressers tonight has seeped into my brain... Read this reply, in my head went, WTF have your abs got to do with your car?
    Feel a bit stupid thinking that now, especially after just having read the entire thread about stupid sh!t chicks do to cars.
    But in all seriousness, thanks for the replies guys, I do appreciate it... Fingers crossed it's something like a rock.
    VE Phantom Black Ute MY10 M6
    Feb 2010
    Does it only make the sound when its cold and your braking while reversing. Mines done it since new. Took it back to Holden, they told me it was something to do with ABS and they were aware of the problem. They still haven't been able to fix it. They basically told me its not causing any problems. I wonder if its been fixed in the series 2.
    VE Clubsport
    Mar 2010
    Quote Originally Posted by paulmac272 View Post
    Yes when cold, but no not when braking. Does it when my foot is not on the brakes. I won't get a chance to get in to see my mechanic this week, will more than likely see him at the footy grandfinal this weekend - will bail him up & suss it out lol.
    VE SSV
    Mar 2010
    Yeah, I have a similar issue. It seems to happen only when the car is cold and when you put the auto into reverse. Even with the foot on the brake the noise is apparent.
    If you let the car idle for 5 min you dont get anything and all is normal. I would tend to think you need to let the car idle for abit to get the oils moving about before selecting reverse.
    I would be interested in finding out whats actually happening when the noise is about.
    VE SS Sportwagon
    May 2010
    Same here. Only noticed it recently and sounds a bit like a stick dragging under the passengers side. Only in reverse, with or without brakes and only when cold. Have it in to the dealer soon so they can have a look then! Auto by the way!
    VE Clubsport
    Mar 2010
    Hmm... I will try that tomorrow morning & see if it works...
    Mine is a manual though...?
    I'm a girl... I'm blonde... But I drive a really nice car
    Ve 6oth anniversary LPG
    Jun 2010
    Hay Guys In answer and what possible cause may be is the Exhaust Shrods seems tobe a common VE fault onece heated and the sheild is warmer the noise goes away I have this on my car and was found tobe Exhaust as I thought it was the auto trans turns out not not really a big job but HOLDEN didnt want todo the job as car was 4000ks out of warranty so they claim even thou the 60ths came with 5 year factory warranty. Good luck hope all goes well.
    VE Clubsport
    Mar 2010
    We have progress... I let my car sit for a few minutes this morning (even though it just about killed me as I was running late for work)... Reversed.. NO NOISE!
  15. #15
    Jun 2010
    Quote Originally Posted by LittleMissVT View Post
    Thats Great probably coz you warmed it up and the heat sheild expanded and it was not that cold in pereth last nite as wat it has been keep an ee on it with the warmer months you may just be ok good luck thou.
  16. #16
    VP ute
    Mar 2006
    I had that happen. Took me ages to sought out what it might have been but in the end it was a rubbish bin under the car. I must have backed over it...
  17. #17
    VE Clubsport
    Mar 2010
    Quote Originally Posted by Fu Manchu View Post
    You didn't manage to notice a rubbish bin under your car? What.....
  18. #18
    SilverVH is offline Banned
    Nov 2005
    Perfect excuse to put an exhaust on it now
    Not only will the noise disappear, but you'll get all the boys trying to race you at the lights in their V6's. Then you can give them a bit of girl power with your 6 litre
  19. #19
    VE Clubsport
    Mar 2010
    Quote Originally Posted by SilverVH View Post
    Haha, the best part of owning a clubsport is the looks from ppl when they see a girl driving it.
    Even better when I take off at the lights & they see the baby toys swinging in the back window
  20. #20
    Nov 2005
    Haha nice! If I'm ever in Perth I know who not to gee up at the lights.
    You should start a thread on your Clubby. They're a nice car
  21. #21
    2011 SV6
    Apr 2011
    Nope, dealer says it's normal, but louder than some. I've got a series 2 sv6.
    Lol at the abs comment! Took me a moment to realize wtf you were on about!
  22. #22
    VE Clubsport
    Mar 2010
    Check out my signature... Says it all hehe.
  1. Scraping Sound When Turning Left
    By vrooom in forum VE Holden Commodore (2006 - ?)
    Last Post: 27-10-2009, 04:27 PM
  2. VS Diff making scraping /grinding noise.
    By robbio12 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-12-2007, 01:16 PM
  3. scraping sound when shifting into Drive/Rev from Park
    By Loungefly in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-02-2007, 10:49 AM
  4. VN Steering Scraping Sound
    By azkwazere in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-08-2006, 09:52 PM
  5. Scraping sound on take off, rear axle soggy
    By count ryxa in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-11-2005, 02:30 PM
