Results 1 to 13 of 13
Thread: VE SV6 leather door trims
    VE SV6
    Sep 2011
    The Shire, Sydney
    Default VE SV6 leather door trims
    Hey all,
    Simple question first - were leather door trims a factory option on a 2008 VE SV6?
    My 08 SV6 has leather seats and leather door trims. It's as I purchased it, second hand, from ex-govt car auctions. I am the cars second owner, previously it was a NSW Area Health Service vehicle.
    I went to my local Holden dealer service dept this morning to get a couple of things sorted out under the remaining factory warranty. One issue was the leather on the door trims look to have shrunk back at the edges. It's like the leather was cut a shade too small and you can just see the mesh backing at the top where the leather edge was glued to the backing. They agreed it was a problem but immediately looked to find a reason to not cover it, including the car not being serviced within the past 6 months despite it only having done 6000 kms since the last service. (What that has to do with faulty door trims, I have no idea.) The door trims were faulty when I bought it. They then accepted my car and later called me up tell me that the trims were not original and might have been a dealer option and I would not be covered by factory warranty, but they would fix the other items (high mount LED brake light fault and software update to fix airbag warning).
    It didn't sound right to me. I figured when the car was purchased, someone ticked the leather option meaning factory seats and door trims. I immediately called Holden customer support and posed the question. "Were leather door trims a factory option for this car?" They didn't answer directly but said they would make some calls and get back to me. Holden then contacted the local dealer who had my car and concluded between them that the door trims were not original and would not be covered. The dealer then called me up to break the news. Fair enough if they are right, but I still think it's sus. My original question remains if the door trims were a factory option and if so then shouldn't the factory cover them?
    If anyone has an insight, I would appreciate it.
    TinSnips's Avatar
    TinSnips is offline Polish all the things...
    VE SS Ute M6
    Mar 2010
    Hills District, Sydney
    From memory, a leather seat option included leather door inserts as well. It would look retarded with a mix'n'match scheme if nothing else.
    astroham is offline PHATV6
    SIDI sv6
    Jan 2010
    Penrith
    Yes leather pack included doer trims ... I was going to get it but the ball and chain wouldn't let me
    2010 SIDI sv6 ... 180atw ... more to come
    VE SV6
    Sep 2011
    The Shire, Sydney
    Thanks, I am seeing a trend emerging... I think I have a case to put it back to holden. The only stumbling block may be if leather was a dealer option not a factory option... Surely factory?
    AE86, VE2 SSV M6 UTE
    May 2004
    Can you post a pic of the door trim? Can probably see if it's original or an aftermarket job.
    Edit:
    I was looking on carsales and found a few sv6's with leather. Factory leather should have a stitching along the crease line on the door trim such as these two:
    here
    and here
    This other one caught my eye though, seems to have red inserts in leather (may have been a factory option, but all others ive seen are just black) and door trims have no stitching on the crease line:
    here
    VE SV6
    Sep 2011
    The Shire, Sydney
    Thanks for that. Mine are all black with stitching either side of the join. I have included a close up pic to showing the problem at the top of the leather panel. The plot thickens!
    Attached Thumbnails Attached Thumbnails VE SV6 leather door trims-100_1222.jpg   VE SV6 leather door trims-100_1224.jpg
    TinSnips's Avatar
    VE SS Ute M6
    Mar 2010
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    I have a copy of the original Commodore brochure which was published when the VE was first released. Leather trim is indicated as an option on SV6's and says nothing about it being a dealer installed option. Given the number and size of components involved, it's hard to believe it would have been dealer installed anyway.
    VE SV6
    Sep 2011
    The Shire, Sydney
    Thanks everyone. I think I have enough evidence to take forward to Holden. Ticks me off that Holden took the dealers opinion that it wasn't OE and didn't investigate further... I will report back tomorrow once I have spoken to them. Thanks again.
    VE II SV6 - Alto Grey
    Apr 2011
    I ordered the option leather trim on mine. However, when it arrived at the dealer 6 weeks later, it had cloth trim from the factory. Dealer screwed up on their order. Anyway the dealer swapped trims with another new stock SV6 that had leather. It took them 2 days, but it looks perfect. So even though mine does not have leather trim code on the plate, it is definitely bought from new with it as my dealer receipt shows... Maybe this is what happened to yours, so go back and check with the selling dealer maybe?
    VE SV6
    Sep 2011
    The Shire, Sydney
    I think I have all the info now - but I am at a dead end.
    Called Holden again this morning. Based on the VIN they looked up what left the factory = cloth trim.
    I called the original dealer it was delivered by them to its first owner - you guessed it - cloth trim (they did have records of service history and fitting rear parking sensors, but not the leather trim)
    The dealer explained one last possibility. The car was for a govt customer but would have been leased through a fleet company. The fleet company may have fitted the leather independently to Holden and the dealer. I guess it is possible. I don't think I have a chance of getting any further with it now. I am sure it is genuine trim but because I won't be able to find who fitted it, it's game over. Such is life...!
    Thanks to all who contributed to this.
    f6
    Feb 2011
    Looks like Pantera leather , maybe contact them and see if they have warranty
    vesv6s2
    Oct 2011
    blakeviewsa
    i have 2nd sv6 with leather it is deff., afactory option.take it back and argue.
  1. [QLD] WTB: VT-VZ Leather seats-frt & rear & Door Trims-Reds or Blacks only
    By VTLS1 in forum Swap / Wanted to Buy / Trade
    Last Post: 09-03-2011, 12:18 AM
  2. [VIC] FS: VX SS FRONT PAIR DOOR TRIMS in VGC and VT/VX FULL SET OF DOOR TRIMS
    By calaiscruzer in forum Parts And Other Items For Sale
    Last Post: 26-11-2010, 08:49 AM
  3. Replies: 6
    Last Post: 11-08-2010, 12:19 AM
  4. [QLD] Holden VY SS Door Cards/Trims Complete - Leather
    By SuperSixty6 in forum Parts And Other Items For Sale
    Last Post: 29-12-2009, 06:36 PM
Tags for this Thread
