Page 1 of 2 12 LastLast
Results 1 to 25 of 26
Like Tree6Likes
Thread: Purchasing VE questions
    The 10th Doctor's Avatar
    The 10th Doctor is offline ambitious but rubbish
    MY06 VE Berlina
    Mar 2011
    Adelaide, SA
    Default Purchasing VE questions
    Hey Guys,
    I'm in the market to buy a new (used) car, and have my eyes fairly set on a VE Berlina. I took it for, like, a 10 minute test drive this afternoon and gave a bit of an inspection.
    It's a MY06 VE Berlina, has about 95,000k on it (so it's due for it's 100,000k service?) and I noticed a few things:
    • Acceleration is better than my bog standard VT (at least, feels that way)
    • Brakes are less sensitive than the VT - has anyone else noticed this?
    Um, yeah, that was about it! Much better than my VTII Acclaim, imho. I'm sorry, these have probably been answered before, but...
    • How can I attach a sub and/or upgrade speakers, while retaining the H/U?
      I've got just the stock speakers with an aftermarket HU in my VT and I'm fairly happy with them so pretty much anything is an upgrade for me. Would LOC's suffice if I want a sub?
    • Is the next service at 100,000k or 105,000k? What would I be looking at that, $$ wise?
    • Would a lower look OK on the stock rims? Likewise, tinting?
    • Does anyone have the manual for VE's online?
    • Can I change the H/U over to one from a Calais? If so, where would I get one from?
    • I'm fairly n00b when it comes to cars, I had a decent look in the engine bay and got the current owner to give it a boot while I was listening, sounded OK. Looked at the spot in garage it had been sitting in, and couldn't see any oil stains. I was thinking of getting the RAA Inspection service just in case.... good idea?
    • Any common faults I should look out for?
    • Does anyone know if there's the equivalent of a REVS check in SA?
    Thanks!
    VE SV6 MY10 SIDI Sportwagon
    Sep 2011
    ve ssv
    Sep 2011
    adelaide
    the 105k's is not a major service, so you should be fine. shouldnt be more than 200, unless you go to holden,
    about the REVS, call transport sa, and tell them your buying a used car, they will tell u all the info about the car on the phone, rather than paying and receiving the certificate.
    EDIT: you may need a new timing belt around the 100k's mark
    VX acclaim S2
    Oct 2009
    Quote Originally Posted by xoom View Post
    Timing belt?? If u find a timing belt in my Ve u can have it, if not I get your house deal?
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    MY06 VE Berlina
    Mar 2011
    Adelaide, SA
    Quote Originally Posted by RiCeY View Post
    Id avoid 06 and 07 VEs personally.
    Why's that?
    2007 VE Lumina
    Apr 2011
    -1 for this.
    I've been driving my '07 Lumina for a little over 12 months now, and it's amazing.
    A very comfortable ride. And with the gas conversion, it's incredibly cheap to fill.
    Just take it for a test drive and make sure you do your research.
    ve ssv
    Sep 2011
    adelaide
    Quote Originally Posted by kizza50 View Post
    0o, didnt know that haha.
    thanks.
    MY06 VE Berlina
    Mar 2011
    Adelaide, SA
    I believe that most Holdens use timing chains, not belts?
    VX acclaim S2
    Oct 2009
    Even holdens today still use the push rod style, rather then over head cams, they use timing chains and not timing belts, so wheres the Keys to my house haha
    VX acclaim S2
    Oct 2009
    -1 also, BILLION DOLLAR BABY
    2009 VE SSV Ute
    Dec 2009
    As a sef confessed "noob", I suggest paying for a qualified mechanic to do a pre-purchase inspection to better inform you on your purchase. Especially as a car with 95000k's will enevitably have some maintenence to do that may not be immediately obvious to you.
    Simmarly, I would leave the speaker upgrade, Calais headn, tints & lowering until you are satisfied with the base car that you buy, your upgrade money may well be better spent on buying a better car ine first place.
    VS Stato l67
    Mar 2009
    Melb
    Do some reading on this site about VZ and Early VE's with stretched timing chain issues. I would make sure the car your looking at wont have the same problem or it might already be fixed under warranty.
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Hey Im only a Holden mechanic what would i know right?
    06/07 had a lot of issues, stretched timing chains, water leaks, electrical issues etc etc.
    Not every single car had this but the chances are a lot higher than if you buy 08 and newer.
    Silver Certified.
  15. #15
    MY06 VE Berlina
    Mar 2011
    Adelaide, SA
    Quote Originally Posted by monkeys437 View Post
    Hmm, there are quite a few threads now I search for it :/ Is there anyway I could tell that it's had it replaced? I looked through the log book, it's been serviced by the logbook regularly but not by a Holden Dealer... If I were to get a pre-purchase inspection done, would the RAA guy be able to tell me if it was or not?
  16. #16
    VE Calais V 6.0L
    Aug 2011
    Calais Head unit will set you back around $1K to $2K after fitting and programming.
    They pop up on eBay from time to time. (There is one on there now for $700, but you will need to get it programmed to work on your car, which can cost anything from a couple of hundred dollars or more.
    A 06/07 Model with close to 100,00Kms should have most of the issues sorted on it by now (with exception to timing chain).
    Check electrics such as switch gear, warning lights, etc. Holden's switch gear is terrible and you may notice problems with the power window switches, steering wheel controls and interior light switch gear which may indicate replacement will be due shortly.
    Likely replacement bits are fairly cheap, so this will be an annoyance factor rather than bankruptcy.
  17. #17
    UFO's Avatar
    UFO
    UFO is offline I Believe
    MY10 VE Sportwagon SIDI 3L
    Oct 2009
    ^this!
    There's a couple of comments above that disagree with Ricey's post, but there's a very good reason to avoid the first releases of a new body shape. Even though Holden spent million's developing the VE (as every car maker spends releasing new cars), there will always be imperfections... imperfections that are improved upon a few years into a new model. Rattles, squeaks, engineering improvements to mechanical parts, etc. are all improved upon in later models as the first 2 years tick by and warranty repairs (or complaints) start coming through and being dealt with.
    There's nothing 'wrong' with 06's and 07's, and this isnt a swipe at the above owners who are obviously very happy with their cars, but it's a valid golden rule when buying a new car regardless of make. Stay away from new releases! Wait a year or two before buying a completely new shape. It's commonsence that issues will naturally arise and be fixed, because no amount of testing will 100% cover actual real life use.
  18. #18
    VX SS
    Jul 2005
    East of Melbourne
    RiCeY seeing as you work on these cars how are you finding the newer SIDI motors, I have been thinking of updating to a VE like the OP and wondering if it is worth spending that bit more for the SIDI versions, is there much difference in the way the 3 litre drives compared to the 3.6 litre?
  19. #19
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    They all feel similar to me but I only drive them for 5 mins at a time.
    Best bet would be someone thats had a non SIDI VE and moved up to a SIDI, they would be able to give a good comparison.
    Silver Certified.
  20. #20
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    Next Question for Ricey, Are you talking about 06 and 07 build dates, or MY06 and MY07 ? I've got an 2007 MY08 Berlina and happy with it.... aside from the near 2 tonne of lard it carries.
  21. #21
    VE SV6 ute
    Apr 2009
    vic
    umm what?? You can have my house and car if you can show alloytecs using "pushrods", if not I get your house and car?
  22. #22
    VE SV6 ute
    Apr 2009
    vic
    Quote Originally Posted by Drewie View Post
    I own a NON-SIDI alloytec in manual, and have been in NON-SIDI auto calais, SIDI sv6 in auto and another in manual. Biggest difference you will find is going from the 5-speed auto's in the NON-SIDI and the 6 speed's. I found a big difference. Not so much in my comparison with the manuals. If it's not much more I'd stretch it to a series 1 SIDI, otherwise I'd stick with a NON-SIDI manual.
    I haven't been in any 3.0L variants, only the 3.6L so can't comment there.
  23. #23
    VE SSV
    Apr 2010
    +1 for getting the RAA to give the car a mechanical inspection, I bought one of the very first VE SSV's (Built Sep 06 off memory) and it is small but worthwhile investment.
  24. #24
    07 VE CALAIS V - V6
    Mar 2011
    Illawarra NSW
    Quote Originally Posted by greenacc View Post
    If you want to ensure your VE is not going to have the known timing chain issue then get one with an engine number after H071380576 as thats when GM identified the problem and changed the OEM fitted chain. All engines with engine numbers after H053340001 had the suspect chains.
    Refer to GMH Bulletin 08-0601-01: Timing Chain Stretch and/or DTCs P0008, P0009, P0016, P0017,P0018, P0019.
    A condition may occur with the HFV6 engine that will cause the MIL to illuminate and may log DTCs P0008, P0009, P0016, P0017, P0018 and P0019. Codes are set when the ECM detects that camshafts on either bank of the engine are misaligned with the crankshaft.
    Fingers crossed no issues with mine but its an auto that doesn't get rev'ed high in short bursts so maybe that may be a reason.
  25. #25
    VE Omega sedan 3.0 2010
    Feb 2011
    Fly Creek, N.T.
    I got a 2010 3.0L SIDI with 67,000 on the odo. I've done another 22,000 since then. I've had no mechanical issues, major or minor, and I'm very happy with it. I got the 3.0 because I wanted good fuel economy, and I have been pleased with that: best I got was 840 km from one tank.
    A good way to get current and recent model cars is the government auctions: that's where the dealers buy their stock, but they load the price up about $6,000. So, if you go to the auction, you can make a big saving right there. I've bought my last three Commodores at auctions.
LinkBacks (?)
  1. 12-10-2011, 04:26 PM
  1. Purchasing a VY SS
    By Mavr1k in forum VY Holden Commodore (2002 - 2004)
    Last Post: 08-04-2009, 11:14 PM
  2. Looking at Purchasing a VZ SV6
    By allun in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 21-03-2009, 08:49 AM
  3. Purchasing a VZ
    By BlueBoy43 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 24-05-2008, 09:12 AM
  4. Purchasing a VS
    By Jards in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-12-2005, 08:26 PM
  5. Purchasing VS 5.0L Ute
    By Nicole in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-11-2005, 02:21 PM
