Hi all, had some trouble today with my new rims.Replaced 20 inch rims with the standard 18 inch ones, as soon as l left the tyre place, had all these faults come up. Abs fault, traction control fault, contact dealer.went back to tyre place,guys from holden dealership came in & hooked it up to the scanner, told me have to do a tech 2 via the net at the dealership. Ended up taking the rims back off, put the old ones back on & got home in limp mode. Is this normal for a rim size chnage? Thanks.
Wrong size tyres? So the diameter was messed up and uneven on both sides? And that's odd![]()
standard size is 245/45/18. new size 245/35/20. Also the tyre guys got an ss ute with 22 inch rims on it, he said this is the first time he came across something like this, hes is a 09 mine an 06 dont know if holden changed anything between the 3 years.
Did u get a faultcode from the guy? N disconnect battery for 10 mins see how u go
Errors came up on my Calais when I had to use the stupid space saver spare in place of a 20" wheel. Have since bought an alloy (same as front wheel) for the spare.
The errors fixed themselves after taking the space saver wheel off again though.
Didnt get a fault code off the guy but did disconnect the battery for well over an hour still getting errors even with the standard rims back on.
Has to be damaged wheel sensor,
I actually thought it could be that too but how do l check it. are they on all wheels?
They are on every wheel, wired how it only happened with wheel swap
oh well, might have to get them checked. Thanks for the help guys.
Could have been a fluke. Tech 2 will be able to diagnose. VEs are becoming famous for dud wheel sensors.
20" g8's? Prefer the machined look
spot on kizza
