Results 1 to 24 of 24
Like Tree1Likes
  • 1 Post By VECom
Thread: Rough idle - what could it be.
    VE Commodore
    Sep 2011
    Hobart
    Default Rough idle - what could it be.
    Hi guys,
    I'm got a problem with my VE (2006) Commodore and was hoping someone here might have some ideas or suggestions on how to fix it.
    It's got a rough idle and has been so for quite some time and it hasn't got any better or worse. When it's cold it idles up an feels good but after 5 or 10 min and the 'choke' is turned off it drops down to 600rpm and it's a very rough idle. It's never stalled and is very steady but shakes the whole car like its on 4 or 5 cylinders.
    I've also noticed if I'm cruising along at about 70kmhr with the engine lightly loaded and about 1250rpm in top gear it's a bit jerky.
    When I start the car up it says 'System check ok' I had a friend who had access to a diagnostic tool and we plugged it in there were no faults in either the engine or gearbox ecu's. We also used it to individually cut each cylinder and they all seemed to have the same effct. i.e. they all appeared to be firing.
    I've replaced the spark plugs and checked the inlet manifold 'o' rings and elsewhere for air leaks but it all looks ok.
    I'm a mechanic so I'd like to fix it myself but not in the industry anymore so no longer have access to a workshop or diagnostic equipment. Replacing parts isn't a problem but what do I replace? Blocked injector, air leak, a sensor?
    Any help would be appreciated,
    Greg
    vl
    Apr 2011
    brisbane
    VE Commodore
    Sep 2011
    Hobart
    my09.5 SS
    Oct 2008
    hunter valley
    VE Commodore
    Sep 2011
    Hobart
    Feels like big lumpy cams Just a pity it doesn't go like big lumpy cams.
    VE Commodore
    Sep 2011
    Hobart
    calais
    Feb 2009
    multimeter, check resistance across 2 terminals on each pack and see if their is any big difference between the 3
    vr commo
    Aug 2011
    places
    Quote Originally Posted by cunno View Post
    ve alloytecs have 6 coils
    VE SS SEDAN
    Dec 2008
    Central Coast
    Sounds similar to what my car is like.
    Ive been told possibly fuel filter issue or oxygen sensors from what i have asked about mine.
    VE Clubsport
    Mar 2010
    Middle of Nowhere - WA
    Quote Originally Posted by shane_3800 View Post
    I don't actually understand what you're all talking about... But from the gist of what I've just read.. 2x3 = 6.
    I'm a girl... I'm blonde... But I drive a really nice car
    VE Commodore
    Sep 2011
    Hobart
    VE has 6x1=6
    Each cylinder has a coil direct on top of the spark plug. Nice design but you can't get the coil off or change the spark plugs without taking the inlet manifold off first. I could test the coils if I had a factory spec to measure them to.
    Fuel filter I would think would be noticeable under load not idle but I could be wrong.
    O2 possibly. Are these in service on idle?
    Craig I've been ignoring it for many months but I've finally conceeded to the fact that it's not going to fix itself so decided to make a bit more of an effort.
    Greg
    vr commo
    Aug 2011
    places
    Quote Originally Posted by LittleMissVT View Post
    the two times three setup on the vn-vy v6's is a dfi direct fire ignition there are 3 coils that earth to them selfs so two sprak plugs fire at once it is also knowen as waste spark
    VE Series II SS-V Redline Sportswagon A6 Phantom
    May 2011
    Shellharbour
    Quote Originally Posted by Gorrell72 View Post
    Sounds like big lumpy cams
    I was going to say, maybe someone gave you a cam job!!!!
    VE Clubsport
    Mar 2010
    Well.. At least my maths was right if nothing else!
  15. #15
    2010 VE SSV ute XYZ XYZ
    Jun 2011
    Dirty air filter? If your fuel consumption is up that may point to air filter
  16. #16
    ve ssv
    Sep 2011
    adelaide
    hmm my car idles at 550ish when its warmed up.
    its my first v8, thought they all idled low?
  17. #17
    VE SS SEDAN
    Dec 2008
    Central Coast
    Quote Originally Posted by VECom View Post
    VE has 6x1=6
    Greg
    Yea im in the same boat as you mate except the 2 mechanics ive been to have told me there unsure lol.
    Mines alittle different but as its pretty jerky down around 2000rpm. It was weird at idle but has since corrected that and now i just have the jerkyness.
  18. #18
    vr commo
    Aug 2011
    places
    VE has 6x1=6
    Greg
    yes o2 sensors work at idle
    maby idle solinoid is getting old
    but i think it is a spark problem knock sensor might be faulty
  19. #19
    VE Commodore
    Sep 2011
    Hobart
    I didn't think they had an idle solenoid but a stepper motor, not sure about it though The idle is rock solid on 600rpm, car just shakes. I think could be coil but not sure how to go about testing them.
    The problem with many mechanics these days they didn't learn old school diagnosis, they just plug the diagnostic gear in and if it doesn't see the fault and tell them what to replace then they have no idea. I don't want to take it to a workshop for them to waste hours on it and charge me for loads of parts they've put on it trying to find the problem.
    I'll do a bit more stuffing around and head scratching on the weekend
  20. #20
    VE SS SEDAN
    Dec 2008
    Central Coast
    Yea for sure.
    Let me no how you go man.
  21. #21
    vr commo
    Aug 2011
    places
    im a young mechanic i hardley use the scantool i have been learing how to use gas benches and scopes but it is all to do with feel my boss can just say check this and bang that is usally the prob
    most rough idles i have seen are spark plug or coil related
    and yea i meant stepper motor
  22. #22
    VE Clubsport
    Mar 2010
    Quote Originally Posted by xoom View Post
    Mine idles around 550 too... I read this yesterday & had to check this morning cos I've never even noticed.
  23. #23
    VS Super6 Utility 5 speed
    Aug 2005
    Cairns, Australia
    These things are FBW so no stepper motor. Coils are a possibility but it would be very obvious if a coil was dead or dying under full load as the increase cylinder pressures would take more coil voltage to jump the spark gap.
    All V6 motors released in Holdens (I can't speak for other brands/countries) are inherently noisy and harsh. It is due to their design "flaw". I would suspect a sagged engine mount if they have been subjected to oil or you have highish kays ie. 80,000km+.
    VN - VY V6 Kalmaker tuning.
  24. #24
    VE Commodore
    Sep 2011
    Hobart
    I did notice there was no throttle cable on it. How high tech the old commodore has got.
    Under load it runs fine and it's as smooth as a bommodore is. Engine mount now that's a possibility. 104k so if that's a known problem then something worth checking. I'll jack the engine and see what happens.
  1. V6 VT rough idle - still
    By DeanoNSW in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-10-2011, 08:34 AM
  2. Rough LS1 idle
    By anvlson1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-11-2010, 06:00 PM
  3. Rough idle, Rough take off and rough stop.
    By Niggadore in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-06-2010, 05:49 PM
  4. rough idle on vt
    By craig_stato in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-07-2006, 08:50 PM
  5. vr rough idle
    By hakhawk in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-02-2005, 12:45 PM
