Results 1 to 14 of 14
Thread: Engine Light after OTR?
    dmacey's Avatar
    dmacey is offline Think about it,
    SSV Series II Sedan Manual
    Sep 2011
    Default Engine Light after OTR?
    hello JCCC,
    After installing a OTR today the check engine light has come on, The diagnostic toll states left and right bank are running lean.
    The new K&N air filter had a substantial amount of oil on it from the box.
    Do you think the O2 sensors and just unable to read whats going on? i'm thinking a highway run to burn it of or take them out and give them a clean and clean to filter a bit?
    Fault code is P0171 & P0174.
    any assistance will be greatly appreciated.
    Heading in for a tune at OzTrack but thats not till Saturday.
    cheers
    Is this it?
    2006 VE SS A6
    Sep 2009
    muswellbrook
    ve ssv
    Sep 2011
    adelaide
    dmacey's Avatar
    Sep 2011
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Where is the air intake temp sensor on these?
    Visit my Facebook page
    dmacey's Avatar
    Sep 2011
    Maf is connected, all sensor are present and functioning as intended. Diagnostic states lean running in both banks. Light switch off after a few hard runs. See what happens on Saturday.
    Is this it?
    VE Series II SS-V Redline Sportswagon A6 Phantom
    May 2011
    Shellharbour
    Quote Originally Posted by xoom View Post
    needs a tune if u removed the maf
    It wouldn't be running if had removed the MAF(without a mafless tune)
    VH SL/E...'09 dual cab 4X4 hilux
    Mar 2011
    roxby downs
    ya probably shouldnt do a few hard runs if its running lean...melted pistons arent fun
    If in doubt......FLOOR IT!!!
    dmacey's Avatar
    Sep 2011
    vx s pack II
    Jan 2010
    aLKIDA
    Quote Originally Posted by dmacey View Post
    hello JCCC,
    cheers
    You said that there was a lot of oil on the K&N filter. Check the MAF sensor elements if they have any oil on them if they do clean it with some MAF cleaner.
    May 2011
    Shellharbour
    Quote Originally Posted by juiceie vh sle View Post
    Yeah I'm with you, I couldn't believe that a few hard runs was being suggested to fix a twin bank lean out warning!!!!! I mean really....Hey look the light has come on and says that I am running lean on all cylinders, mash the foot, a little detonation will fix that, she won't be running lean anymore!!!!! She won't be running..........
    Rufys is offline Banned
    VE Series II Calais Sportwagon
    Aug 2011
    OMGWTFBBQ?!?!?!?!!!! You say you know it's running lean and then drive it hard??? WTF are you smoking??? Cause soon it will be the smoke from the grenade that goes off under your bonnet!!!
    [edit] ok so other people beat me to it... lol
    dmacey's Avatar
    Sep 2011
    Quote Originally Posted by PRAVX II S View Post
    you are on the money mate
    A code P0171 may mean that one or more of the following has happened:
    The MAF (Mass Air Flow) Sensor is dirty or faulty. Note: The use of "oiled" air filters may cause the MAF to become dirty if the filter is over-oiled. There is also an issue with some vehicles where the MAF sensors leak the silicone potting material used to protect the circuitry.
    There could be a vacuum leak downstream of the MAF sensor.
    Possible Solutions
    Possible solutions include:
    In the vast majority of cases, simply cleaning the MAF sensor does the trick. Consult your service manual for it's location if you need help. I find it's best to take it off and spray it with electronics cleaner or brake cleaner. Make sure you are careful not to damage the MAF sensor, and make sure it's dry before reinstalling
    Inspect all vacuum and PCV hoses, replace if necessary
    Check for a dirty fuel filter and proper fuel pressure.
    all is well.
    Everyone else can relax, for a moment i thought i was talking about your car lol
    Is this it?
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Im guessing an air leak after the maf, most likely where the OTR fits onto the throttle body. I see this all the time where it hasnt slid over the throttle body properly at the base and allows unmetered air into the engine hence the lean mix.
    Silver Certified.
  1. ENGINE light, ABS light, TRAC OFF light AIRBAG light and OIL light
    By jamierawr88 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-10-2011, 09:06 PM
  2. Vt 5.0 idle problems and missing also engine light and oil light come on
    By vtss5.0 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-07-2011, 07:32 PM
  3. HELP Engine Light / Transmission light and rough gear changes
    By flash20005 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-10-2010, 03:34 PM
  4. Engine stops, fuel light on, battery light on GOODBYE
    By scarletx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-06-2009, 03:43 PM
  5. Battery light & Check Engine light
    By Sledge in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-09-2008, 06:30 PM
