hey all, over the last few weeks the note from the left hand exhaust on my ss has changed dramatically from the right side.it is now a much tinnier sound with a flutter about it. the right side is still the deep rumble its always been.is the muffler stuffing up or do i need a balance pipe installed or is it something else? a bit confused,what do you recken it might be or any remedy,s. thanks.
Hazy 64
no, a Lukey 2.5
Hazy 64
Has it been on long? They have a two year warranty.
only been on the car for about 8 months but the car shop i bought it from has since closed down and i fitted the system myself.
Hazy 64
All i can think of is, you cracked a hole in it? Ohwell Good reason to sell it and buy KPM ...
no, ive checked it from extractors and all the joins,no cracks or leaks.the muffler is a simple straight thru design.got me baffled!
Hazy 64
intake leak left hand side only.... or dodgy exhaust which is much more likely
to check for a leak did you block exhaust with a rag the left hand side??? if no try this...
if you think its a muffler faulty then take it back to where you bought it... if no
warranty at least they should give you a discount...
could be ur cat mate.. I had the same thing with my difillipo system on my vz
the cat you say.ok have a spare cat in the shed,will fit it up and see what happens.thanks guys.
Hazy 64
