Results 1 to 2 of 2
Thread: ve ssv check engine light after battery died?
    ve ssv
    Sep 2011
    adelaide
    Default ve ssv check engine light after battery died?
    hey guys, was a couple days that i didnt drive my car.
    passed week, i noticed that the car took longer to start up,
    it was passed shopping hours, so i couldnt buy a new battery, but my dad helped me jump start it for tonight to use.
    i used to a obd scanner and it says that my crankshaft sensor is in fault. error code is P0336 Crankshaft Position Sensor Range/Performance
    any idea's how i can fix this? or would i have to take it to holden?
    thanks.
    im also getting traction control off, and i cant seem to turn it back on
    Damo83 is offline VE MY09 SV6
    VE MY09 SV6
    Sep 2006
    Perth Western Australia
    I had a flat battery before and jumped start from Rac , engine light came up I guessed it was the battery fault causing it. However i disconnected the battrey and fitted new battery . Left it disconnected for few hours as it reset the whole system. Engine light went off when u started my Ve . Hope This helps? If it's still on, Holden can reset the system for u. Shouldn't be much.
  1. Engine died at 100kmh then check engine light up ?
    By calaismity in forum VE Holden Commodore (2006 - ?)
    Last Post: 17-05-2011, 09:58 AM
  2. ve flat battery and check engine
    By Lumps of cheese in forum VE Holden Commodore (2006 - ?)
    Last Post: 20-02-2011, 08:41 PM
  3. Engine stops, fuel light on, battery light on GOODBYE
    By scarletx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-06-2009, 03:43 PM
  4. Battery light & Check Engine light
    By Sledge in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-09-2008, 06:30 PM
  5. Battery dead again! Check Engine Warning!
    By joshtaylor87 in forum VE Holden Commodore (2006 - ?)
    Last Post: 14-08-2008, 07:55 PM
