Results 1 to 4 of 4
Thread: adjusting boot on 2006 ve calais
    2006 calais v
    Oct 2011
    campbelltown
    Default adjusting boot on 2006 ve calais
    hi all,
    i have a problem with my boot lid on my 06 calais v, when it is closed it sit up about 2 or 3 millimetres above the side panels and tails lights, is there any way that you can adjust the boot via the boot clip or any other way so that when it closes, it closes down further?
    Silver VE Calais 3.6L
    Oct 2011
    Melbourne, VICTORIA
    I too have the same problem. I've tried adjusting the latch in the boot but didn't seem to work!
    VE Calais V
    Jun 2006
    Christchurch
    I had a similar but opposite problem on mine. The front of the boot lid was too low on mine.
    The front part of the bootlid height is set at the hinges. The rear part of the lid & the height, in relation to the top of the taillights & to the top of the rear bumper, is set by the height of the boot latch & two large adjustable rubber grommets under the rear of the bootlid.
    To adjust the front part (closest to the rear windscreen) try the following.....
    There's a stop on each side, you can adjust up or down, with a rubber or plastic grommet on top of it. It is located on the base part of each boot hinge from memory. Adjustment of these, combined with loosening the bootlid retaining bolts & adjusting there gave mine the desired result.
    I would suggest, for yours, to firstly remove the little grommets off the adjustable stops & see if that changes anything. If so try winding them down some - till you get the desired result when grommets replaced.
    If that dosen't work you might try adjusting from the hinge bolts. The bootlid height can be slightly adjusted by moving the hinge at the base mount (where it bolts onto the car body each side). A word of caution when loosening the boot hinge bolts, as you may loose correct fitment if you aren't careful.
    To adjust the rear part try this.....
    There are two large adjustable rubber grommets under the rear of the bootlid. These are threaded & can be wound up or down to set the height at the rear. This affects the bootlid height to the top of the taillights. If the grommets are wound out too much it may hold the lid too high when shut. Try winding the grommets in & see if this lowers the boot for you. This may give enough adjustment on it's own but I suspect it won't. There is a balance between the latch pulling down & the grommets pushing up to keep the lid in postion & taught so it doesn't rattle around.
    If more adjustment is necessary try this. Remove plastic inner rear boot liner panel by removing the plastic clips. Remove the boot latch completely. Close the boot down & hold it closed to gauge the fit & height. Adjust the rubber grommets till the boot sits at the correct height. Replace the latch & adjust its' height till it holds the boot tight & leaves it sitting at the right height in relation to the lights. You may need to slot the holes on the latch to acheive the right adjustment.
    All that may fix your problem, but my not give you enough adjsutment. My friends bootlid was way too low & we had to slot the front holes on the hinge base mount to fix his.
    I was a panelbeater years ago so didn't hesitate to do this. It is not that hard to do, but if you are unsure it may be worth handing over to a tradesman to tackle if annoying you.
    Oct 2011
    Melbourne, VICTORIA
    Thanks heaps stirringaxe.
    Boot lines up perfect
  1. My 2006 VE Calais
    By calais06 in forum VE - WM
    Last Post: 16-03-2012, 10:45 PM
  2. adjusting boot gaps
    By adam81 in forum VE Holden Commodore (2006 - ?)
    Last Post: 08-10-2011, 10:55 AM
  3. [VIC] VE Calais 2006
    By cds in forum Vehicles For Sale
    Last Post: 11-10-2010, 10:42 AM
  4. Adjusting the height of the rear of the boot lid
    By rancid_b in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-09-2009, 01:13 PM
  5. adjusting gas struts in boot?
    By fat_tyre_nick in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-07-2005, 10:46 PM
