Has anyone taken their engine out of their ve ss themselves? How hard is it and how long did it take you?
VE SS 6LTR
Remove exhaust and tailshaft, disconnect everything from engine and gearbox and put axle stands under the subframe and gearbox them remove the 6 subfame bolts and gearbox crossmember and raise the car leaving engine and gearbox behind.
This only works if you have a hoist haha
Ive done it in less than 4 hours.
Silver Certified.
That must be a record lol. Well I dare say I'll be letting the shop do all that then..
VE SS 6LTR
haha practise makes perfect. You could probably lift it out the top with a engine crane...
Silver Certified.
correct me if im wrong but on the VE's does the radiator support and the rest of the front unbolt? haha wish i could practice a little less valuable to me
VE SS 6LTR
Ive always dropped them out the bottom so not sure about the rad support. It is plastic so Id assume it would simply unbolt..
Silver Certified.
Just gotta be careful not to flex the engine mounts when your lifting the engine out, the bulkheads on the ve's are quite large so would be interesting too see if the motor wil come up high enough without hitting anything
Sent from my MB860 using Tapatalk
Apparently down at Lang Lang, they've taken to removing them from the top. But we always bring them out the bottom aswell.
Originally Posted by Reaper:
Originally Posted by Jecs:
Thanx for all the info guys but ima let the pros do their thing.. Could end up costing me more pain/money if I attempt this one myself..
VE SS 6LTR
