Results 1 to 4 of 4
Thread: VE SS mufflers for SV6
    VE SV6, VX Executive II, VS Esteem
    Jun 2010
    Default VE SS mufflers for SV6
    Looking at doing this mod. I undertsand it olts straight on but will it fit with just the standard rear diffuser??
    And are there any gasketsor anything else that i could find potentially worn when i attempt this?
    Havnt found any mufflers as such yet so if any1 has any they dont want lemme no =) $$
    Commodore
    Jun 2004
    NSW
    there are hundreds of topics on this
    do a search
    It will bolt on, and it will fit diffuser as bar is the same on sv6 and ss
    You can reuse gasket if they are not that old or just get two new gaskets from holden
    There are 2 bolts on each side and it will take no more than 20 min to do it...
    Easy to do...No need to jack up the car or anything....
    Ebay is your best bet for cheap mufflers....
    PS> true twin tip will drone on sv6.... one pipe out branching into Y tips will be fine
    Jun 2010
    ve wagon
    Oct 2011
    colac
    Dan, the rear diffuser on the sv6 is the same as ss. dual tip on ss mufflers will bolt straight on. No other alterations needed. I just put dual system on Omega wagon and looks muck better.
  1. SS Ute Mufflers
    By Probes in forum VE Holden Commodore (2006 - ?)
    Last Post: 11-08-2011, 09:07 PM
  2. [NSW] WTB VE SS mufflers
    By Xonar in forum Swap / Wanted to Buy / Trade
    Last Post: 11-02-2011, 05:09 PM
  3. VE SSV Mufflers vs HSV Maloo Mufflers
    By vakaviti in forum VE Holden Commodore (2006 - ?)
    Last Post: 11-12-2010, 04:25 PM
  4. No mufflers
    By cobja1 in forum The Pub
    Last Post: 12-10-2010, 06:09 PM
