Results 1 to 5 of 5
Thread: Ve oil cooler
    Ve ss ute
    Sep 2011
    Default Ve oil cooler
    Hi all,
    Trying to find an oil cooler for my 2011 Ve ss manual L77. I've found a L98 oil cooler adaptor on aseturbo but I'm just trying to find out if the l98 adaptor will fit the l77? As far as I know it will, because the only difference between l98 and l77 are the internals, but I'd like to be 100%. Iv sent an email to ase but got no reply.
    Can anyone help? Thanks!
    Darcon666's Avatar
    Darcon666 is offline Evil is always around you
    The Wife
    Jun 2010
    At home
    Contact PWR and they will sort you out and if the fittings are not right Pirtek can help...
    Now, A few more details as to what type of "Oil Cooler" are you after(Engine, Gearbox, Power steering, Diff etc. etc. etc...) would help everyone, help you.
    Ve ss ute
    Sep 2011
    Sorry, it's an engine oil cooler I'm after. Thank you, I'll have a look at pwr and see what they got. I know harrop have a kit but most kits I find are $600-$700, this adaptor is only 100ish and I'm sure I can get a cooler and lines for under $500!
    VE SSV 60th Ann
    Oct 2010
    A mate got the ASE adapter for his Series 2 SSV so I know it should also work. He also went the route of a PWR cooler and Pirtek fittings etc rather than buying a full kit (ASE and Harrop both do one for about the same money). Apparently, at the end of the day, his kit has ended up costing the same as those two kits but he has got a much bigger cooler.
    Bonners White E3 Clubsport - SV Enhanced
    Wortec Brakes Distributor
    Ve ss ute
    Sep 2011
    Righto I checked out pwr and they didn't have anything for the ve, but I emailed them and they said they'll have an oil cooler kit coming out within the next month! Also, ase got back to me and said the oil cooler adaptor should work if my l77 has the standard sump! I think I'll be going with the ase kit $650 ain't to bad
  1. Auto Trans cooler or oil cooler?
    By Dr.304 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-04-2011, 10:01 PM
  2. VN 3.8 Oil Cooler
    By TimmyVn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-05-2010, 07:06 PM
  3. VS Oil Cooler
    By RazzaCaine in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-05-2010, 02:18 PM
  4. oil cooler
    By jas98 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-08-2008, 01:53 PM
  5. oil cooler
    By VNCommo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-04-2006, 11:15 AM
