Results 1 to 15 of 15
Thread: Installing Wireless Reverse Camera.
    None
    Nov 2009
    Default Installing Wireless Reverse Camera.
    Hi Everyone,
    I purchased a gps unit which comes with a wireless reverse camera.
    I need help installing the camera.
    The unit is here:
    7" GPS HD CAR NAVIGATION+WIRELESS REVERSE CAMERA+8GB | eBay
    I live in maidstone and would really be thankful if someone could guide me through installing it, I can do it myself just need help from someone who is experienced.
    I'am happy to come down to your place or vice-versa just to make sure I'am doing the right thing.
    The car I have is a Holden Berlina VE.
    Appreciate all the replies.
    None
    Nov 2009
    None
    Nov 2009
    None
    Nov 2009
    VE MY10 SV6 A6
    Feb 2010
    Regional South Australia
    2010 SV6 Ute
    Sep 2011
    Wollongong
    what part are you having trouble with? the listing has instructions.
    . Just unscrew your number plate
    2. Align the holes of the wireless camera to the existing number plate holes
    3. Using the original number plate screws, screw fix camera on the top bit of the number plate
    4. Wire the power cable of the wireless camera to the nearest reverse light, it is where the reverse camera and the built-in wireless transimtter gets the power from. Wiring is simple, RED to RED, BLACK TO BLACK.
    5. Let's move to the driver seat: Connect the wireless receiver to the GPS (AV cable and power cable) on one end and the car charger on the other end.
    6. The GPS will automatically switch to reversing screen when your car is in "R" gear
    7. How does it work?
    When a car is in "R" reversing gear, the two little bright reverse lights at the back of the car are ON. The wireless transmitter and the reverse camera immediately receives power and start transmitting camera signal to the air. The wireless receiver which hook up the GPS and car charger pick up the signal. It tells the GPS to switch automatically to GPS's AV channel: reversing screen in this case.
    The Dark Knight is offline The Dark Knight
    VE SV6 Thunder MY11
    Jan 2010
    See it sometimes helps if you read the instructions if they are that simple.
    I would not have been able to help you but those instructions seem fairly easy to follow if they were in front if you
    itsArthurKomar is offline sexy beast
    super awesome time machine
    Apr 2011
    ya asss
    hey mate ive done the exact same unit on my mate skyline, whawe did is we spliced into the reverse light wires in the tail light and hooked it up easy to do, get a multimeter and find out which wires ar the reverse light wires or get a spare light bulp and play around with the harness untill yoou find the right wires then just solder it in and heat shrink
    VE BERLINA 07
    Jan 2011
    Rowville Melbourne Vicotria
    Quote Originally Posted by kunalraiker View Post
    Hi Everyone,
    The unit is here:
    hey i also have a ve berlina and i found these pictures on a facebook profile i wanted to the this unit of ebay as well but i want it built in to my car like the picture below
    Installing Wireless Reverse Camera.-223085_207939449254831_100001163319479_571240_5365468_n.jpgInstalling Wireless Reverse Camera.-284653_207939542588155_100001163319479_571242_7675938_n.jpgInstalling Wireless Reverse Camera.-284938_207939489254827_100001163319479_571241_747138_n.jpg
    I'm a boy who appreciates a good body, regardless of the make.
    None
    Nov 2009
    Quote Originally Posted by itsArthurKomar View Post
    Ohhh Cool, when you say play around with the harness what do you exactly mean?
    Quote Originally Posted by matt30186 View Post
    I read the instructions, all I need to know is which cable is the reverse light?, can someone take a picture of their car and highlight the wires I need to cut, can this be done witheout cutting the wires?
    Thanks again for all the help.
    Apr 2011
    ya asss
    playing around with the harness i mean just needed to find out wchich wires did what since he had aftermarket tail light sett up and it was absolute shit... and it had a solid block connector.......
    yes all you need to know what is thhat the reverse ligth wires. and DONT cut. just slice off the lastic around it carefully and solder the wires in and either heat shrink which is pest option, or electrical tape whcih you will probably have to youse ill see tommoroow if i can get to the wires
    <RaBBiT>'s Avatar
    <RaBBiT> is offline Follow the White RaBBiT>>
    95 VS Berlina 5.0,VN Wagon 5Spd 5.0L
    Nov 2007
    [SA]
    that little gps look quite kool
    If Barbie's so popular, why do you have to buy all her friends?
    None
    Nov 2009
    I managed to find the wires, green is for red and black for black.Installed the reverse camera successfully.
    Thanks Guys!
    None
    Nov 2009
    Quote Originally Posted by <RaBBiT> View Post
    It is isn't it !, love it specially the price I payed.
  15. #15
    Apr 2011
    ya asss
    sweet pics of the install would be cool
  1. Reverse parking camera Ute
    By havoc in forum VE Holden Commodore (2006 - ?)
    Last Post: 18-01-2010, 12:17 AM
  2. Reverse Camera
    By vz 914 in forum VE Holden Commodore (2006 - ?)
    Last Post: 04-11-2009, 04:06 PM
  3. VE reverse camera
    By tcooper in forum VE Holden Commodore (2006 - ?)
    Last Post: 15-02-2009, 12:19 PM
  4. Reversing Camera - what camera to get and where to connect my reverse wire?
    By ozzie_online88 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 02-07-2008, 03:27 PM
  5. Reverse camera /monitor
    By commodore2004 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 24-11-2006, 06:15 PM
