Results 1 to 2 of 2
Thread: VE Grange Question (Removal of MRC)
    VT Calais
    Apr 2007
    Default VE Grange Question (Removal of MRC)
    i had some noise issues with the suspension on my 07 grange, turns out the shocks have leaked & will need to be replaced.
    is there any issue if i replace the MRC shocks with either standard HSV shocks from a GTS or coilovers?
    they failed with 90k on the clock & is out of warrenty. i would like an easy solution without stuffing the ride quality.
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    You could replace them with normal HSV shocks but you wouldn't be able to use the MRC or maybe get some good quality coil overs.
  1. Quick question vs grange
    By VL-EXEC in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-09-2010, 09:08 PM
  2. 304 Grange/215i Question??
    By pedrotski in forum V8 Development and Modification
    Last Post: 04-09-2009, 10:55 PM
  3. Quick inlet manifold removal question
    By gontix in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-04-2009, 06:58 PM
  4. speed sensor removal question
    By h0Ld3n`VN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-11-2008, 12:19 PM
  5. is this a silly question, VP 5.0l starter removal
    By FCCOOL in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-12-2005, 09:55 AM
Tags for this Thread
