Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By Rufys
Thread: ve sv6 diff
    astroham is offline PHATV6
    SIDI sv6
    Jan 2010
    Penrith
    Default ve sv6 diff
    ok so i have just been informed that my diff is f'd ... great (my fault though i guess) ... so i am looking at putting a better diff into the car ... any suggestions on what brand / ratio to go
    just to clarify i have a 6sp manual sv6 ve ... i know there is other threads on this but all i could find was people recomending manual ss diffs for autos ... are the ss diffs stronger than the sv6?
    2010 SIDI sv6 ... 180atw ... more to come
    VE SV6 ute
    Apr 2009
    vic
    the stock diff in the SIDI's is an LSD 3.27 ratio I think from memory, so just look at replacing it with one of those. I'd honestly just look at replacing it with a second hand diff of the same ratio or like a SS diff 3.45, just make sure it's LSD.
    I'm pretty surprised the diff gave way though, surely thats a Holden warranty job??
    Jarp's Avatar
    Jarp is offline Surely You Jest
    SV6 MY10
    Dec 2009
    Think the standard diff is LSD in the ute but is a single spinner in sedan. I've a 3.27 single spinner with only 5000kms on it if you are interested PM me. If you want a better diff I'm running a 3.7 LSD in mine and it is excellent....about $1800 brand new from Holmart.
    VE Calais V 6.0L
    Aug 2011
    To give you some ideas,
    I saw an LSD 3.27 on eBay a month or so back that went for around $500 with 70,000Kms on it.
    I just purchased a 2.92 LSD from a Clubby with 80,000Kms for $380.
    (Berlina and Calais V8 models dont get LSD as standard, hence the reason why I just bought, and about to fit a LSD version soon).
    VE Calais V 6.0L
    Aug 2011
    Here is a rough guide as to what diffs were fitted to what models...
    Please dont take it as gospel, Holden had LSD as an option on a lot of these models, and Holden did make many running changes over the life cycle of the VE.
    3.6L Alloytec Dual Fuel LPG Engine - 4 Speed Automatic - 3.27 Non LSD Differential
    3.0L SIDI Direct Injection Engine - 6 Speed Automatic - 3.27 Non LSD Differential
    3.6L SIDI Direct Injection Engine - 6 Speed Automatic - 3.27 (Optional LSD on SV6 Models)
    3.6L SIDI Direct Injection Engine - 6 Speed Manual - 3.27 LSD Differential
    6.0L V8 L98/L76 Engine - 6 Speed Automatic - 2.92 Differential (LSD Standard on SS, SSV Models, optional on Calais, Calais V)
    6.0L V8 L98/L76 Engine - 6 Speed Manual - 3.45 LSD Differential
    HSV Automatic Models - 2.92 LSD Differential
    HSV Manual Models - 3.45 LSD Differential
    Rufys is offline Banned
    VE Series II Calais Sportwagon
    Aug 2011
    What happened to the 3.7 in the HSV manual???
    Destroying a diff in a V6 Commodore? WOW!!! That takes some serious driving (or just small amount of dumb).
    Jarp's Avatar
    SV6 MY10
    Dec 2009
    Soz for the misinfo didn't realise the LSD was stock on the manual 3.6 SIDI.
    VE SV6 ute
    Apr 2009
    vic
    Did you have many problems with calibrating the new speed on the 3.7 diff Jarp?
    Jarp's Avatar
    SV6 MY10
    Dec 2009
    Quote Originally Posted by kuzman89 View Post
    I did initially but both CHE and MACE can recalibrate the speedo now although the MACE fix is more accurate according to my GPS.
  1. 304 I need a new diff.. well I want a new diff..and mine's noisy..so..I need a new diff.
    By Warranty Void in forum V8 Development and Modification
    Last Post: 24-05-2010, 02:19 PM
  2. Changing vx diff do you have to unbolt the whole rear end or just the diff unit
    By H1GHROLLR in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-11-2009, 06:35 PM
  3. changing diff gears or full diff replace?
    By callum_88 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-05-2009, 06:59 PM
