Results 1 to 7 of 7
Thread: No A/C after 30 seconds on SS Ute.
    VE SS Ute '08
    Jun 2005
    Woonga, VIC
    Default No A/C after 30 seconds on SS Ute.
    2008 VE SS Ute (Not an SSV)
    Hi All,
    I have an issue where everytime I start my car, the A/C works normally and can be adjusted etc, then after 30 seconds the vent setting automatically changes to screen, fan goes to low setting and all the A/C buttons are non-responsive.
    If i restart the car, the same sequence of events is repeated.
    Also possibly of note, occassionaly (approx ever 200 or 300th start) the entire centre dash console is dead (i.e. no radio, display, A/C) and I have to restart the car to get it working again.
    Any help appreciated.
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    My dash has gone blank a couple of times over a year or so, I remember some saying it was a couple of hundred dollars to get it fixed something to do with the head unit display controller.
    bladerunner's Avatar
    bladerunner is offline AUSTRALIAN MADE AND OWNED
    VE SS UTE
    Nov 2010
    brisbane nth
    i remember reading about this drama on ls1.com. i'd check with dealer as from memory there is a techline for it as in a software fix
    im out of my mind at the moment...please leave a message
    TinSnips's Avatar
    TinSnips is offline Polish all the things...
    VE SS Ute M6
    Mar 2010
    Hills District, Sydney
    Had this happen to mine, oddly caused the seat being replaced (coincidence obviously - reconnecting the battery caused the HVAC module to crap itself) ... The module was reset with a Tech 2 and all has been fine since. Not sure if that's the techline or not - the bloke working on my car had never seen the issue before.
    VE SS Ute '08
    Jun 2005
    Woonga, VIC
    Ok I will keep this in mind, its going into the dealer on Thursday so i will let you know an outcome when I get one.
    VE SS Ute '08
    Jun 2005
    Woonga, VIC
    The dealer couldnt see any error codes, and as it is intermittend they couldnt reproduce the problem. Working fine at the moment but no real answer to the problem.
    TinSnips's Avatar
    VE SS Ute M6
    Mar 2010
    With mine, it didn't throw any codes - but the bloke could tell from plugging the tech2 that the HVAC unit wasn't communicating with whatever it was meant to be communicating with. He reset it and it's been fine since - though I did need to monitor it for a while incase thhe HVAC module needed to be replaced.
  1. motor will run for 5 seconds then stop
    By william2011 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-07-2011, 11:37 PM
  2. 0 to 200 in 6 seconds
    By madnuts in forum Jokes/Humour
    Last Post: 17-04-2010, 01:52 PM
  3. Easiest way to get 0-100kms in less the 6 seconds??
    By Nzpure in forum V6 Development And Modification
    Last Post: 10-06-2009, 09:11 PM
  4. 0 To 200 In 6 Seconds
    By Dirbatua in forum Jokes/Humour
    Last Post: 10-02-2008, 02:52 PM
  5. vp 0-100 6 seconds flat WTF
    By vks in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-02-2007, 08:39 PM
