I've been serching for a while for photos or instructions on how to remove the pannel but I've had no luck. It's the pannel that sits under the rear window in the cabin behind the seats, has anyone removed this before? Any info or photos of how to remove this would be much appreciated.
Thanks in advance
You're talking about the parcel shelf, right?
Upgrading VE Stock Speakers - How To
Scroll to the bottom of post #1 under the title Subs
His is a ute not a sedan.
You have to remove the passenger seat, trims along the bottom of both doors and the B pillar trims/trims around the small windows.
Remove the baby seat anchor/s and under both flaps at the base theres small screws you also have to remove. Once you remove all the screws it unclips then carefully slide it our the passenger door, get someone to help.
Silver Certified.
Cheers for the reply, that sounds like a lot more effort then I originally thought, I definately will have to get some help with it. Thanks again RiCeY
How did u go, as i am going to do the same and i was told if you remove passenger seat the seat belt pretensioners may have to be reset on the computer
Just disconnect the battery before unplugging and dont reconnect battery till seats are connected back up again.
Silver Certified.
Thanks, all done managed to refit sub and amp under seats better than autobarn had them and feed the twoway aerial lead through the back panel
