My mate is looking at putting his 08 sv6 sidi ute on the dyno but apparently if it goes over 200km/h it throws ABS fault codes.. Does any one know if it's true and if so what fault codes?
Cheers brandon
It will show a code at any speed above 30Kph I think because the front wheels are not turning and the rears will be turning making the car believe the car there is something wrong with the sensors, it won't hurt your car though.
I found my Vy was going nuts with the Abs fault codes on a skid pan, every time the car would crack around 100 in wheel spin the trip computer was beeping away
