Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By RUF-60L
Thread: Cigarette Lighter, socket has power but lighter not working
    VE SS-V, V8, 6 Speed Manual
    Apr 2009
    Question Cigarette Lighter, socket has power but lighter not working
    Hey all,
    So my VE SS has the VE smokers kit fitted which gives you an ashtray and a 12v / cig lighter down the bottom of your dash.
    the issue i have is, any 12v plug device i plug in works fine and has power with no issues.
    but the actual cigarette lighter itself doesnt stay in when i press it (to heat up)
    - and when i hold it in manually (doesnt get much hotter than luke warm and definately never hot enought to make the coils go red)
    so i figured that it might be the actual lighter piece itself, and got a new one from holden.
    plugged it in, same thing!
    there might be something i am overlooking here like, handbrake must be on to use the lighter? or stationary to use it? key to Accessory only?
    i've tried a few things but i cannot get it to heat up properly.
    i might just add, i NEVER smoke in my car. EVER.
    its just handy if i dont have a lighter on me to be able to heat it up and light the ciggy outside of the car.
    its just little things like these after gettin a second hand car that are just a minor pain in the arse.
    tips/thoughts appreciated,
    thanks guys,
    Timmo
    RUF-60L's Avatar
    RUF-60L is online now Donating Member
    2008 VE SS
    Nov 2010
    quit smoking, problem solved! hahaha
    just stirrin ya hopefully someone has an idea of whats wrong
    Quote Originally Posted by dingdong555 View Post
    Be careful not to hit yourself in the head whilst pulling
    My Ride, RUF60L
    Apr 2009
    VE Berlina Sportwagon
    Aug 2011
    Wantirna, Victoria
    You may have an issue with a poor electrical connection on the cigarette lighter. Possibly the earth connection on the socket may not be as good as it could be and it might have some slight DC resistance. For example the gauge of wire going to the cigarette lighter might be too light. The gauge of the wire from the earth side of the cigarette lighter socket might be too light. The connection from the earth side of the lighter to the metal earth of the car might not be electrically good enough (which would be my guess). Where the 12V wire to the cigarette socket was connected into the existing wiring might be a poor connection.
    When you run something that draws some significant DC current, such as the cigarette lighter, it is most important that all the connections are good quality and the gauge of wire is appropriate (able to run 15Amps or more). If they are not then you will get a voltage drop over the connections (or even the underated wire) and you will not be getting the full 12V across the cigarette lighter so it won't get as hot. Devices that draw lower currents that you plug into your cigarette socket, such as a GPS, won't be affected as much by lower gauge wire or poor connections and will probably work normally.
    I would try your cigarette lighter in someone elses car (probably doesn't need to be a Holden) to see whether it works. Try a known good cigarette lighter in your socket as well.
    For example if you cigarette lighter has a DC resistance of 1 ohm (and that's a guess) then it will draw 12 Amps assuming all the connectors and wiring are of insignificance resistance. If you have a DC resistance in your connectors of 0.5 ohms then when you plug the lighter in only then there will be a voltage drop of 4V across the bad connectors and wiring and therefore only 8V across the cigarette lighter (the voltage you get across cigarette lighter is a ratio of the resistances). It all work off ohm's law V=IR (V = voltage, I = Current, R = electrical resistance)
    Cheers.
    VE Clubsport
    Mar 2010
    Middle of Nowhere - WA
    Quote Originally Posted by timmo666 View Post
    I smoke in my car. Not the end of the world.
    Good luck with fixing it.
    I'm a girl... I'm blonde... But I drive a really nice car
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Put a multimeter on it and see how many volts you have.
    Silver Certified.
  1. VZ No power to cigarette lighter socket
    By davevz in forum Electrical Wiring / Questions
    Last Post: Today, 03:09 PM
  2. cigarette lighter/ power acc not working
    By surfdog in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 09-09-2010, 09:24 PM
  3. VY Cigarette Lighter Socket
    By pedrod59 in forum Electrical Wiring / Questions
    Last Post: 17-07-2008, 05:15 PM
  4. cigarette lighter socket
    By VYMAD in forum VY Holden Commodore (2002 - 2004)
    Last Post: 19-06-2008, 11:39 AM
  5. WTB VS Cigarette Lighter Socket And Leads
    By weedo_86 in forum Swap / Wanted to Buy / Trade
    Last Post: 22-03-2007, 02:35 PM
Tags for this Thread
