Results 1 to 9 of 9
Thread: Removing ve sv6 series ii rear spoiler
    VE Commodore Series II MY12 SV6 Phantom
    Jan 2011
    Default Removing ve sv6 series ii rear spoiler
    i was wondering if taking off the rear spoiler is an easy job?
    it looks like its just a 4 screws and u just plug them.
    is it that simple? and does it scratch the paint at all?
    Commodore
    Jun 2004
    NSW
    yes
    undo 4 nuts and pull it of
    there is insulating rubber/foam under there so it should not leave any marks at the mounting points
    Jan 2011
    Homer's HSV's Avatar
    Homer's HSV is offline Homer Simpson
    VE E3 Clubsport
    Feb 2010
    Jan 2011
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    06 VE SS
    May 2009
    Rockingham, WA
    Quote Originally Posted by nugsy View Post
    what is the size of the hole that needs to be plugged?
    Undo the 4 nuts,pull it of and clean the area.
    Use 10mm rubber grommets from repco.They are under $5 for four,then just paint the tops of the grommets with touch up paint to match your car and thats the job done.
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Quote Originally Posted by RiCeY View Post
    Same size as the holes in your boot.
    Ba ha ha ha ha ha!
    What color is your car maybe you could just swap boots with someone?
    Jan 2011
    [QUOTE=
    What color is your car maybe you could just swap boots with someone?[/QUOTE]
    black phantom
  1. Problem removing rear spoiler
    By Owned in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-07-2010, 11:29 AM
  2. [NSW] VS Senator rear spoiler, VS SS rear spoiler and series 2 VS Calais front bar insert
    By shanhsv in forum Parts And Other Items For Sale
    Last Post: 24-06-2010, 07:11 PM
  3. removing a rear spoiler?
    By callum_88 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-12-2008, 06:56 PM
  4. removing rear spoiler
    By arrow in forum General
    Last Post: 21-02-2008, 11:13 PM
  5. removing VS SS rear spoiler
    By pHiLix in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-09-2005, 06:39 PM
