Results 1 to 14 of 14
Like Tree1Likes
  • 1 Post By bonners
Thread: $800 to Replace a Loose Gear knob
    08 VE SS Black 20" BILL LEE MOD
    May 2011
    Default $800 to Replace a Loose Gear knob
    Hello....
    Done a search and can't find the advice I need. My 6 speed manual gear shaft on my SS is loose. I have pulled apart and replaced the knob after the stealer quoted me, but found the shaft is in two pieces there is remnants of black stuff where it sits against the gearbox shifting shaft thing.
    On a service with the stealer they quoted $800 to fix what was described as a loose gear knob. Are their any other options? Is something broken or missing
    A slow1
    Nov 2005
    UFO's Avatar
    UFO
    UFO is offline I Believe
    MY10 VE Sportwagon SIDI 3L
    Oct 2009
    take it to a transmission specialist and get them to quote you if you cant do it yourself.
    stuff the dealers!
    TinSnips's Avatar
    TinSnips is online now Polish all the things...
    VE SS Ute M6
    Mar 2010
    Hills District, Sydney
    dmacey's Avatar
    dmacey is offline Think about it,
    SSV Series II Sedan Manual
    Sep 2011
    VE SV6 Commodore
    Sep 2009
    Perth, WA
    Same thing happened to me. The shaft broke away from the plate or something. And the plate had to be replaced.
    Luckily it was still under warranty, I'm guessing yours has run out already?
    VE SSV 60th Ann
    Oct 2010
    $800....... Holy fark... I've heard of rip off before but thats crazy.
    I'll write this response to help you perhaps find some use out of it but help others if they ever had an issue
    Now, it depends on a few things and I figure I do know some of this stuff because you and I have the same car:
    Is it just the knob? It has a locating part that sits in a slot in the shaft. It could quite simply have come up out of that. Simply rotate the knob around with a small amount of downward pressure and it should find the locating slot. The give it a bit of a tap with a rubber mallet over a blanket or something and all should be good. (I'm disgusted if this is the fault and holden quoted you $800 to do so).
    Is is the shaft itself which has broken away from the linkage? This may be more expensive and the labour to fix this would still be high but sorry still not $800. And I'll give a reason in a minute. If the shaft has broken loose at the bottom (I find unlikely but my VE has thrown up some furffy's and think anything is possible) then the grab the actual shaft below the knob (Basically grab hold of the shaft where the leather boot is) and see if it is the part moving. If the knob stays tight but moves when you grab the shaft then that is the problem.
    I had a ripshifter put in my car. They basically have to take the whole assembly out, unbolt the exhaust - technically not a hard thing but an involved thing.My dealer installed mine for me and charged me $100. I dont have my shifter anymore as we had to take it because of some gearbox issues. I would certainly recommend short shifter to fix the slushy VE box. But I am actually going to get a full replacement one.
    Generation 5 Camaro Short Throw Shifter
    I am organising a few to be imported already. If anybody is perhaps interested, I could see if they would be interested to change it to a group buy.
    Bonners White E3 Clubsport - SV Enhanced
    Wortec Brakes Distributor
    TinSnips's Avatar
    VE SS Ute M6
    Mar 2010
    Hmmmm... might be interested, Bonners - what's it like compared to a billet shifter? Have you had a chance to sample one? Would appear to be a bit of a saving over a billet, if the quality and feel is comparable.
    VE SSV 60th Ann
    Oct 2010
    Tin, we have simply decided to take a plunge. I have tried a ripshifter and a hurst. The thing we like about this unit is that it's a complete replacement. Still cheaper than a ripshifter and about the same as a hurst.
    Ve r8 , VL turbo
    Oct 2011
    Camden
    Ripshifter that's all you need to know will fix it and feel alot better too
    May 2011
    Thanks Bonners... I replaced the gear knob with the redline version only $120 to see if it was that. No luck after having a look just like you suggest the shaft which holds the gear knob is broken away from the linkage (smaller looking shaft). Looks like a transmission place is most economical way. At the join to the linkage is some black powdered stuff like a worn gasket looks.
    Does Holden use black superglue or something... bloody dodgey!
    How much u reckon for the Short Throw? I might be interested.
    Quote Originally Posted by bonners View Post
    VE SSV 60th Ann
    Oct 2010
    They are $350 plus shipping. I'm hoping with enough people we can get it to around $400 or less shipped. Problems though are it will be cheap to get a few shipped here to one address but then we run into duty problems. Therefore I'm hoping they will give me discount with a big number and they ship direct to you
    2007 VE SS
    Nov 2006
    mine seems to be shagged aswell. it seems that the knob is not properly fixed to the shaft. it will turn (like opening a jar) and even pull upwards 'off' the shaft.. any help appreciated!?
    May 2011
    That's the exact problem vkhg farq its annoying, I'm just wondering if ever I had a bingle that insurance could render it as a possible cause of poor maintenance and reject a claim. Hence why I want to make sure it is fixed
    Quote Originally Posted by -vkhg View Post
  1. Gear Shifter Loose
    By Shtato in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-12-2009, 06:01 PM
  2. VS gear knob
    By bazzii1388 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-07-2009, 10:36 PM
  3. VP SS Gear Stick Loose?
    By Venom_SS in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-07-2009, 11:46 AM
  4. Gear shifter loose?
    By ozzie_online88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-06-2006, 11:12 PM
  5. Loose gear knob ... manual SV6
    By destorman in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 04-08-2005, 01:50 AM
