I recently bought an SSV late MY10 sports-wagon particularly for the AFM feature. Unfortunately it has a constant vibration coming from the engine (I assume from there) when in 4cyl mode. It's not just at the change over, it's constant. Here in Melbourne I travel the full length of EastLink and for the bulk of that trip the problem is very noticeable on such a smooth road. As soon as the transmission switches to 8cylinders the vibration stops.
My local Holden dealer is not very supportive, stating they are not a representative of Holden and are not very proactive in assisting me. I have waited over 3 weeks for them to contact Holden engineers to find a solution to this rare problem. They tightened the exhaust system but that didn't change anything other than now I have a rattle when I go over bumps. The car wasn't bought from there as I got it from a dealer in Sydney and drove it down.
I was wondering if anyone else is having a similar issue or had one and found a solution? I love the car and very disappointed that for most of my driving it's vibrating!
Regards,
Wayne
I would look into getting AFM disabled most performance tuners can disable AFM also if you switch the car into manual gear changes it wont shut down to 4cyl. I have AFM and I havn't had a vibration problem with mine.
Thanks for the suggestions though I would like to solve the problem if at all possible as I would like to get the fuel saving benefits of the AFM feature. After all that's why I bought that model in the first place.
Do you have a sports exhaust fitted?
Can you provide a little more info about the car itself, such as any modification to engine, exhaust etc. Also when you say you have a virbration in AFM mode descibe it, where do you feel it mostly (steering, drivers seat, front or rear end of the car, whole car) does it vibrate at idle waiting at the lights?
Is there any harmonic noise associated with the virbration (do you get a drone or booming like sound inside the car when its doing it). Are there any abnormal noises (metalic) while the engine is running.
If the car still has the complete (exhaust manifold, cats and catback) exhaust system, they are fitted with flex joint at the cats and at the rear of the intermediate system. I have heard of flex joint failing at the cat end (where they bolt up to the cast iron exhaust manifold) and causing problems such as virbration and droning when in AFM mode.
As for fuel savings, stats provided by owners of AFM cars suggest they are only saving a maximum of 1ltr per 100klm of fuel more over a long highway trip than non AFM equiped V8s. In some cases where owners of AFM equiped cars have had the engine management system tuned (by a well known tuner) they have achieved better fuel economy with the AFM mode turned off.
But this might not be your cup of joe and I can understand you wanting to get the matter sorted. As for your Holden dealers response that they are not a representative of Holden (corporation) I disagree, they promote, sell the product and service it. They carry out warranty work on behalf of Holden and are instructed by Holden on how to carry out repaires. I think this makes them very much a representative (IMHO). As your vehicle is still covered by a Holden Factory Warranty I would advise Holden Customer Assistance of the claim made by the dealer and your difficulty in having your issue resolved in a timely manner.
Regardless of the location where you bought your vehicle you should not be penalised for taking to any dealer in the country and make that point clear. It appears that carring out warranty work by dealers is becoming less important and will delay customers as long as they can.
How does the transmission disable 4 cylinders?
Hi mate,
I have what appears to be quite similar, when my car goes into 4cyl mode it vibrates through the wheel which is more annoying on the highway where it just sits in 4cyl, i even tap the accl pedal to put it in 8cyl when it gets to annoying sometimes, id even call it a slight grating feel, but only in 4cyl mode.
I took it in once and they re hung the exhaust but made no diff, and i havent had the time to take it in again, its exhaust related i reckon but why and were i dont know......
IF YOU BUILD IT THEY WILL COME.... STILL WAITING LOL
AFM vibration tends to vary between vehicles. My own car is noticeable but not annoying and most drivers wouldn't feel the vibes increase a little.
My friends sedan is very noticeable and feels like a tailshaft balance vibration (but its only the AFM). Many other AFM owners here on JC have mentioned various vibe levels too
I don't know a technical reason why some engines are different but I do know that actual dynamic balance of production engines does vary. Comes down to manufacturing tolerances. If you get a lucky mix of spinning components with close weights then your engine will be smoother than the next one off the line.
AFM works by closing both inlet & exhaust valves after the cylinder draws its intake stroke. It then uses the air/fuel mix as a compressible spring to assist the mass of the dormant cylinders to keep turn'in. Obviously many other things happen to make it all work but I could be bothered typing
Maybe if your engine had a slightly leaking valve to allow one of the cylinders to loose its pressure and unbalance the whole show then this might produce more vibs. Dunno just fish'in here...
I suppose in a perfect environment AFM makes sense but unfortunately does not appear to live up to the economical expectations. But for a 6.0 ltr, their not too bad.
VE II SS-V Sportwagon
If that's the only problem then get it tuned and turn off the AFM, you'll get better fuel economy and more power.
And the biggest bonus is you can get rid of the tree hugging badges.
Hi Hexem, It's a stock standard car, ex GMH fleet actually. The vibration occurs as soon as the indicator in the dash displays 4cyl mode and goes when in 8cyl mode. It's not a harmonic noise etc. in fact there is no noise really and the car runs beautifully other than the vibration. It's not real strong/less noticeable on a rougher bitumen road. But on smooth tarmac it's very evident. You can feel it more noticeably as the driver through the pedal and is definitely coming from the front of the car/Drive train as in engine/transmission not tyres, suspension etc.
Thanks for your interest
Mine (MY11 SSV Wagon) works fine on AFM and I too want to keep it enabled, even when I have it tuned. I have no vibration or anything when it goes into AFM. I just wanted you to know it's possible for it to work fine, for sure.
I'd select a different dealer. What area are you in?
Reaper
The Doncaster dealer is next to work, But I live down at safety beach
I was told a similar thing. They tightened mine with no change. They told me how one guy had his entire system replaced and no change so doesn't sound like it is Exhaust related. he is now taking Holden to court as it was on a new Statesman. Take it out of auto and go into sportshift so it can't change to 4cyl when its bugging you
If I end up with no luck getting this sorted, where would you recommend i go to get it disabled and more efficiently tuned?
What fuel do you use, I only use 98 and always have and dont have this problem. I cant tell the difference between 8 and 4 modes. Thank god. At least our shit box does something right.
Engine vibration in V4 mode is normal. My SS vibrated in V4 mode. With the stock exhaust it's barely noticable, if you change the exhaust tho it really kicked up in vibration and dreadful noise going in and out of V4 mode. With an exhaust it sounds like it throws up when it cuts back to V8 mode.... yuck.
I have HP Tuners, so I just disabled the V4 mode. I was worried about economy but with a few tweaks I got more power now and better economy. V4 mode is hopeless for daily commutes if you live anywhere where your going up and down hills.
I spend 65% in the city, 35% highway. I got about 400km to 64ltr with V4 mode enabled. With v8 mode only and some tweaking, I get around 450km to 62ltr. I wanted sound V8 sound so I trialed a number of diff back exhausts, none of which will work with V4 mode enabled.
V4 is only good for like Sydney to Melbourne trips if you have constant speed on a highway, other then that it actually stuff's the cars fuel trims, causes more knock retard (even if only Burst Knock) all of which kill economy. The biggest reason why V4 mode killed my economy was because it was forever switching back and forth and thus had twice as much work to do with compensating for burst knock mostly etc. (cutting power to ensure the engine runs good and doesn't run into knocking constantly).
V4 mode really is something that should be left to a VVT setup I personally think. Trying to get a pushrod motor to be efficient by such measures is a waste of time. You can tweak deacceleration fuel cut off and other things to help economy to compensate so.
V4 mode was a really dumb idea. This is probably why 99% of tuners disable it and still improve economy......... AFM is annoying to tune and really offers no benifits not to mention it's obviously bad for the engine if you took thru all the protection gear in the tune when in V4 mode.
PS. The vibration is essentially caused by two things. One the engine itself and two the exhaust being designed for v8 resonance, not v4. Anyway thats my two cents from having an SS and starting to tune it for the past 2-3 months. I'm pretty sure even your Holden manual for the car says in it somewhere you'll have some minor vibration but thats normal.
2009 VE SS SILVER SEDAN - Twin Amps... Tune in progress (more for response and power) then outright KW on a dyno
are you taking it to Frankston Holden?
For those guys who have had the AFM disabled and the car tuned are there any cons to this or has any one had any issues arise?
cheers
Cruzer,
I have not heard of any issues arising from friends who have the AFM setup disabled. Everyone of them have commented on how much better the car drives.
Phil
I have the same vibration in my ve ssv redline sportwagon. Holden dealer said engineers think its exhaust done up too tight when it leaves the factory, so they loosened it (engineers advised to do this) and it has gotten worse. I feel it on the pedal and in the steering wheel. My car is going back to dealer next week and if they cant resolve it I wont give up till they replace the car, cause it just aint on!! I also have problem with the brembo's, they've machined the disks once already and the problem is there again so I will be requesting all new brakes. I have had the carpet replaced, an ss badge replaced, wheels rotated and 3 wheel alignments. So far I'm not very impressed with the SII ve.
^^ Sorry to hear. Sounds like you got a "Friday car".
There is no need to loosen the exhaust. The AFM exhaust setups have flex joints the Cats to engine headers and at the rear just before the mufflers. You can see these yourself just by putting your head under the back of the car. The flex joints were used on the AFM cars to reduce vibration and exhaust drone when in AFM mode. Loosening the exhaust will only introduce other problems (as your experiancing).
The exhaust system fitted to non AFM vehicles does not have the flex joint and yes at RPM in 6th gear you do feel a small amount of vibration resonating from the exhaust. I would probably start with checking to make sure the exhasut hangers are positioned correctly and the exhaust is not being pulled to tightly in one direction. The look to replace the exhaust rubber hangers.
