Results 1 to 17 of 17
Like Tree1Likes
  • 1 Post By kizza50
Thread: Quick Exhaust Question
    2008 VE SV6 - Ignition
    Jan 2007
    Mackay QLD
    Default Quick Exhaust Question
    Just wondering how easy/difficult it is for some to do an exhaust fit themselves of something like this: Here : for a SV6?
    Like, is it a process of lifting the car, bolting some crap on and away she goes? Or is it safer to get a pro to do it all and not go through eBay?
    EDIT: Yes, I know there is an exhaust thread.. But I don't want to search through a hundred pages for a quick answer >_<
    itsArthurKomar is offline sexy beast
    super awesome time machine
    Apr 2011
    ya asss
    its pretty easy if you have the right exuipment , but for the xforce systems you need to allign them so they fit properly so i recoment taking it to a exhaust shop will save you alot of time
    Jan 2007
    Mackay QLD
    Munz's Avatar
    Munz is offline Right Foot Action
    VZ Calais LS1 / VL RB30e daily
    Jan 2011
    Brisbane NTH
    sv6
    Feb 2010
    there relatively easy to bolt up, just need yourself a good jack and some proper stands will save you some cash. As mentioned to ensure alignment is correct set the rear of the muffler into the correct position in the rear bumper before you tighten everything up.
    cheers
    VX acclaim S2
    Oct 2009
    Jan 2007
    Mackay QLD
    Apr 2011
    ya asss
    well you can try it yourself no one is stopping u just would be alot faster and easier to get it done by shop haha :P
    Quote Originally Posted by jbray1984 View Post
    You're all tempting me to try it myself lol.
    Jan 2007
    Mackay QLD
    Okay, well let's say I try it myself... Worst case scenario, what could go wrong?
    Am I going to wreck something on the computer side of things that might cost me more to get fixed?
    06 VE SS
    May 2009
    Rockingham, WA
    Try it frist yourself,if you can't do it take it to the local exhaust shop.
    ve ssv/vr calais V6 turbo oneday N/A Track car
    May 2010
    Rockhampton QLD
    Its an easy to do job get the car up on some stands as high as u can to make life easy
    its just nuts and bolts and a couple of rubber hangers. The rear muffler hangers can be a little bit of a pain to get in If you put a bit of lube on the rubber hangers it make getting the rear mufflers into the mounts easy. also just keep an eye on where the rear hangers sit cause if you dont get it right the exhaust tips will sit either to high or to low and you will have to pull the rear mufflers out of the hanger and try again. take your time and you should be fine
    Jan 2007
    Mackay QLD
    Awesome as. Sounds like fun
    Thanks all for the info. When I have decided what I'm going to buy I'll probably run it by the forums first to make sure I don't buy the wrong thing
    May 2010
    Rockhampton QLD
    Troy711's Avatar
    Troy711 is offline Moderator Puppeh
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    If you know a mechanic with a hoist they will probably do it for a case of piss provided you give them a hand.
  15. #15
    Jan 2007
    Mackay QLD
    Quote Originally Posted by Troy711 View Post
    Unfortunately not... Moving to a new town shortly so will barely know anyone but my brother
  16. #16
    Apr 2011
    ya asss
    yeah nothing will be dammaged just be carefull around the removal of the O2 sensors cause they are screwed in quiet tight and yeah then should be sweet i had to take mine to exhaust shop coz i couldtn get em of and there was one of the bolts that just couldnt come of with out using a rattle gun lol ####en rusted in
  17. #17
    Jan 2007
    Mackay QLD
    Someone mentioned in another thread that the SV6 already has a 2.25" system through it already? And says there is no point as to putting another 2.25" system on it, even if it is branded Xforce or anything. But didn't go on to clarify.. Any thoughts on this? Recommends only doing the mufflers.
    Is there something I'm missing?
  1. Quick exhaust question...
    By nathanVY in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-08-2011, 09:22 AM
  2. Quick exhaust question
    By Rusty in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-02-2011, 02:30 AM
  3. just a quick exhaust question
    By stato98 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-09-2010, 12:25 PM
  4. Quick Exhaust Question.
    By jokerflingo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-02-2010, 10:25 PM
  5. Quick exhaust question...
    By spd_dmn in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-09-2008, 05:30 PM
