Results 1 to 2 of 2
Thread: VE Series 2 stereo install Help NO SOUND OUT OF RIGHT CHANNEL headunit / IQ
    VU S2 Manual
    Sep 2009
    Default VE Series 2 stereo install Help NO SOUND OUT OF RIGHT CHANNEL headunit / IQ
    Hi I have jut installed a full system into my thunder ute, have had a small bit of trouble with wiring and amps but have now got wiring etc spot on, however I have lost all sound out the right channel, nothing at all straight out the headunit. I've tested everything and I have even hooked a single speaker straight direct out of the right channel to test and have absolutely nothing.. Does anyone know what the problem might be is it possible to blow internal fuses on individual channels in the headunit? Pretty stressed out that I may have damaged the IQ...any help is much appreciated
    The X Man's Avatar
    The X Man is offline Donating Member
    VE SERIES II SV6 SIDI
    Feb 2010
    Outputs aren't fused in head units, some have protection circuits built in but if you have removed the loads and connected a speaker directly to the head unit and it still doesn't work then i would say something in the output stage of the iQ system has been damaged. In this case i'd put it back to stock (if possible) and go back to Holden for a warranty claim. I doubt warranty would be offered once they realize things have been modified.
  1. Replies: 0
    Last Post: 07-11-2011, 08:55 PM
  2. No Sound from VE series 2 stock stereo
    By GregFonz in forum VE Holden Commodore (2006 - ?)
    Last Post: 17-08-2011, 11:16 AM
  3. VS Series II Stereo Install..
    By inais in forum Car Audio
    Last Post: 23-11-2007, 08:38 AM
  4. 4 Channel anp install, speaker level inputs
    By AshK in forum Car Audio
    Last Post: 26-09-2007, 11:43 AM
  5. Vn new headunit install help!!
    By H00LiGaN in forum Car Audio
    Last Post: 22-05-2005, 10:02 PM
