Page 1 of 2 12 LastLast
Results 1 to 25 of 27
Like Tree6Likes
Thread: What to do.. Screw in tyre
    VE II SV6 Sportwagon
    Sep 2005
    Angry What to do.. Screw in tyre
    Just noticed a screw in my front tyre, and would just like advice on what to do.
    I know the rule of thumb is to not touch it, though not knowing how long the screw is, and taking into consideration i still have a fair bit of tread depth, i'm wondering if it has pierced the carcass or not..... and also thinking as the tread wears down, its only going to push the screw further in.
    Can i get it repaired? and if so how much is that roughly and is that a temp fix or is it a legit 100% safe long term thing, as the tires are still like new... ####ing spewing!
    Jonno's Avatar
    Jonno is offline :)
    Nov 2010
    Vic,
    go to a tyre shop and get them to put a puncture repair,
    just to save your self some money so u dont have to buy a new tyre
    Quote Originally Posted by Rufys View Post
    yup! I think I might actually be gay
    TinSnips's Avatar
    TinSnips is online now Polish all the things...
    VE SS Ute M6
    Mar 2010
    Hills District, Sydney
    A tyre shop should be able to plug that without too many issues. I think it was about $30 last time I needed it done and took about 20 minutes. Works fine. Repairs are allegedly fine even for track use - apparently. Certainly fine for the road though.
    Enter the Model/Class of your Commodore. i.e. VL C
    Sep 2008
    You can leave it there the head of the screw will just wear off or take it to your preferred tyre place and they will repair it for you for $10-$40.
    Rufys is offline Banned
    VE Series II Calais Sportwagon
    Aug 2011
    The repairs are also stronger than the tyre too. So no worries about integrity.
    ve ss
    Nov 2010
    Darch WA
    go buy a punture plug kit from your local car store,about $15 or $20 and fix it yourself.you get 5 or 6 plugs in the kit and your good to go in 10 mins.i always carry one in my car as you never know when your going to get a punture.very easy to do and will pay for itself after one punture.most tyre shops charge $20 to $30 to do the same thing you can do yourself.
    Hazy 64
    Verynice's Avatar
    Verynice is offline Band
    VS Caprice 5L
    Aug 2008
    SA - The Backwards State
    Quote Originally Posted by glennho View Post
    lol, thats a temporary fix to get you out of trouble until you can get to a tyre place ang get it repaired properly.
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Some places may say thats too close to the edge to repair, just so youre aware.
    Silver Certified.
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    They'd be able to fix that no dramas.
    Troy711's Avatar
    Troy711 is offline Moderator Puppeh
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    ve ss
    Nov 2010
    Darch WA
    Quote Originally Posted by Verynice View Post
    the tyre shop will do the same fix with a plug unless you specify you want a patch put on the inside of the tyre.
    Hazy 64
    Verynice's Avatar
    VS Caprice 5L
    Aug 2008
    if its a good tyre shop, they will do it properly the first time, if not, they will put in a temp one which only takes a couple of minutes and about 10 bucks to get you out the door.
    and they will especially put in a temp one, say, if the tyre is almost bald anyway, not worth spending 30-40 bucks on a busted tyre.
    Hangman's Avatar
    Hangman is offline Torana Addict
    2 commys, 3 Toranas and a WB Panel Van
    Jan 2010
    Newcastle, home of Toranafest
    $20 bucks for a plug the last time I got it done at a tyre shop. Had it done a couple of times, never had any issues.
    Quote Originally Posted by hakhawk View Post
    there are more pressing issues on the site, like choosing between vl's and potatos.
    Xw GT replica/Vr s ute/Ef
    Jul 2011
    NSW
    we get them done for $7 i think its called a bung.
    Originally Posted by 87RB30VL
    Huh? I got given the gun of my neighbour,
  15. #15
    ve ss
    Nov 2010
    Darch WA
    got a plug in my nissan patrol tyre,been there 4 years,done some hard core 4 wheel driving.no problems.the plugs are vulcaniser plugs which are an acceptable form of repair or otherwise every tyre shop in the land would not be using them!
    Hazy 64
  16. #16
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    I normally just leave them till the tire starts to loose air. Easy enough to repair though. Some places might complain about it being too close to the edge though.
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
  17. #17
    UFO's Avatar
    UFO
    UFO is offline I Believe
    MY10 VE Sportwagon SIDI 3L
    Oct 2009
    1) leave it in, dont touch it.
    2) take it to tyre shop. they will remove it and patch it properly. they'll actually seal the hole in the tyre with stuff that'll never come out.... basically bonds with the tyre completely.
    but dont ignore it. get it fixed.
    nice pics btw
  18. #18
    one_and_only2004's Avatar
    one_and_only2004 is offline Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
    My mate who is a tyre fitter at bridgestone is staring at you funny via the internet. Every tyre I've had fixed (had one exactly the same as the OP - self tapping screw from work) has been taken off the rim and had a patch applied to the inside of the tyre. Cost me $20.
    VZ Thunder - 360RWKW Turbocharged V8 - Parts by AKO Performance Tuned by BPS
  19. #19
    VE SV6 MY10 SIDI Sportwagon
    Sep 2011
    In my opinion that screw only looks to be 20mm long, i doubt its even pierced past the tread.
  20. #20
    Vr ss & vy v6 wagon
    Jan 2010
    Central Coast, NSW
    i have worked in a couple of tyre shops and not one of them used a rope plug as im pretty sure they are illegal.
    (the only place that did was jax tyres but i only lasted there 4 days because the owner was an all round dodgy ####,not just with punctures)
  21. #21
    2007 VE Lumina
    Apr 2011
    I had the exact same thing about 4 weeks ago, except my tyre went flat.
    Cost $30 at the local Tyre Factory.
  22. #22
    VY S2 HBD Calais 5.7 & VS S1 185i Caprice
    Mar 2010
    Echuca Vic
    I had the exact thing 2 weeks ago. Quick fit patched the inside odf the tyre properly $25.00 in & out in 20 minutes. Perfect result.
  23. #23
    Sep 2005
    Quote Originally Posted by Troy711 View Post
    Looks like its been there a while.
    ye its probably been a week or two.... noticed the ticking when i had the windows down the other day and picked a couple of stones out of the tread on the right hand side, but was still ticking, so checked the left and bingo...
    Quote Originally Posted by Phantom6 SportWagon View Post
    yeah im guessing its just a 20mm tek-screw from in front of work or something, so thats one of the main questions ive got, is if its even pierced the tyre yet.. bit of a gamble not knowing how long the screw is though...
    and cheers to everybody else that has replied, will get it sorted on the weekend.
  24. #24
    Sep 2005
    all sorted guys.
    they slugged me $35, but whatever, did it on the spot took all of 20 minutes.
    again cheers to all that actually helped and not so much for that one bloke who was a smart ass, though i noticed the mods have obviously deleted his (and trailing) posts
  25. #25
    Tim Smtih's Avatar
    Tim Smtih is offline Sexy Man
    VXS1 Acclaim Family spec Limited Hardcore Edition
    Sep 2009
    Here.
    Bit late i guess but yeah kmart tyre and auto charged me $30 to fix a 6inch nail in my tyre.
    http://tinyurl.com/MetalisAwesome
    Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.
    Albert Einstein
  1. IS IT STUFFED or ARE THEY TRYING TO SCREW ME OVER
    By kerrie0400 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 04-06-2011, 11:46 PM
  2. Where is the Bleed screw?
    By Phantom VK in forum VY Holden Commodore (2002 - 2004)
    Last Post: 26-01-2009, 09:44 AM
  3. Screw this for a drivign course.
    By barely legal in forum The Pub
    Last Post: 15-11-2008, 10:30 AM
  4. screw through exhaust tip
    By fuzzy2308 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-11-2008, 09:44 PM
  5. why does the MAN screw us???
    By MikeVXSS in forum The Pub
    Last Post: 13-04-2006, 06:15 PM
