So the bluetooth in my Calais V has stopped working, can't even find it when searching with multiple devices.
I am going to take off the glovebox and have a look at the Bluetooth module but I have two questions:
1 - How do I remove the glovebox?
2 - How do I test the Bluetooth module to see if it is dead or not?
Cheers,
Mat.
Glovebox is removed by removing all the visible phillips screws along the top and 2 underneath the glovebox door. Theres another 2 screws hiding behind small trims on each side that you can see when the glovebox is open.
Small chance the module wasnt plugged in correctly and has disconnected.
Delete all pairings from your phone, disconnect then reconnect the module and try again.
Silver Certified.
Well the Bluetooth is now working again!!!
Pulled the module out a few times, nothing was obviously wrong with it. Reset a few more times and also reset the phone a couple of times too.
Will see whether the problem comes back or not.
Thanks for the tips Ricey
No worries happy to help.
Silver Certified.
