Results 1 to 9 of 9
Thread: ve ss thud noise when selecting 1st and changing to second
    ve ss v
    Nov 2011
    victoria
    Default ve ss thud noise when selecting 1st and changing to second
    hi all, i recently bought my self an 07 ve ss v manual and recently noticed when i put it in 1st from being stoped it makes a thud noise and also when i change from 1st to 2nd, and you can feel it going into gear? but if i give it and change from 1st to 2nd i cant notice it? any ideas?
    Ve r8 , VL turbo
    Oct 2011
    Camden
    ve ss v
    Nov 2011
    victoria
    so even at a complete stop and selecting first yoy can get backlash from thd diff? Can this be adjusted?
    Ve r8 , VL turbo
    Oct 2011
    Camden
    Yeah it can be adjusted . Yes it can still happen when your stopped and going into first it's the car taking up the slack in the driveline. Best to get it checked out by your mechanic though
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    +1 same as above!
    TinSnips's Avatar
    TinSnips is online now Polish all the things...
    VE SS Ute M6
    Mar 2010
    Hills District, Sydney
    Had a similar issue - was diff backlash. Adjusted under warranty - it's better but not 100%.
    2007 VE SS
    Nov 2006
    TinSnips's Avatar
    VE SS Ute M6
    Mar 2010
    VZ Acclaim
    Aug 2007
    Default Yep same here. 07 SS
    Mine was mainly when cold and would thump into 1st. Took it back to the dealer and they replaced the whole trannie under warranty.
    Punch it Chewie!.....................It's not my fault!!
  1. transmission weird noise when selecting reverse
    By sawychri06 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-10-2010, 01:21 PM
  2. LSD Thud Noise?
    By MSE089 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-12-2009, 01:35 PM
  3. Rear Thud noise when changing gears???
    By futronix in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-03-2006, 08:20 PM
  4. mettalic thud noise, when down changing to 2nd at 65kph
    By sp001in in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-03-2006, 08:30 AM
  5. Noise when selecting gears
    By gone_nutz13 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 31-10-2005, 07:49 PM
