I am installing a Trailer brake controller in my VE SS.
The panel under the steering wheel needs to come off so that i can mount it above your left leg, but i can not see any screws attaching it. Giving it a few getle pulls and it seems attached somehow.
Has anyone removed this panel that can shed some light on how it comes off.
Thanks
Scott
Hey Scott,
Here is a page I found from the tech manual. Hope it helps.
instrument_panel.pdf
Just pulls off. Some need a bit of effort too.
You will need to remove the plastic bit just above the pedals, before you remove the knee bolster panel.
Very easy to do, should take less than 5 minutes to get access to it all.
Have a look at this page,
(Scroll down to about half way, and it describes what you need to do to get access to and remove this panel)
www.carmodder.com • Upgrading Instrument Clusters for the Holden VE Commodore
Click on the images if you want to see them in High Res.
You can remove and refit the trim under the steering wheel without removing the plastic trim above the pedals.
Silver Certified.
So i have taken off the trim and the result is 1 clip broken.
This was not that easy to remove a lot of force was required to budge those clips.
I will take a pic in the next couple of days of the back of the trim so you can see the location of all the clips
