Results 1 to 23 of 23
Thread: Headlights acting weird
    calais06's Avatar
    calais06 is offline Donating Member
    VE Calais MY06
    Jul 2011
    Sydney, NSW
    Default Headlights acting weird
    Hey all,
    The last couple of days my low-beams have been acting weird.
    Yesterday both low beams were working, and then when I got in the car a couple of minutes after it was off both low-beams wouldn't turn on. Every other light (High beam, fogs(hid), Parker's, indicators and brakes work). I have checked all fuses and connections to the ballasts.
    Then this morning the right low-beam was working and left wasn't. Any ideas what couple cause this intermittent issue? Both low-beams are HIDs and were only installed 3 months ago.
    Anything else I could check would be appreciated.
    **dont flame for beings HIDs, my lights are projectors, adjusted at he right angle**
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Mine will intermittently do that if I start the car with them on or if AUTO headlights are on and I'm in a dark location. I've learnt to turn to parkers before starting my car. The ballasts seem to have protection in them to prevent the quick ON/OFF/ON when the engine is turning over.
    calais06's Avatar
    VE Calais MY06
    Jul 2011
    Sydney, NSW
    Yeah, I normally turn them off before starting the car as I have noticed that too..
    Would unplugging them and plugging them back in reset said 'protection' mode? Just odd how both aren't working when its normally just one if I forget to turn them off before cranking.
    WL CAPRICE
    Mar 2011
    Same here my hid kit does the same.
    Good to hear that it isn't only mine.
    I thought I had a dodgy set.
    Is there a real fix for it like changing the fuse for the low beams to a higher resistance therefore not cutting out so easy.
    I don't think that's really safe thou.
    Any suggestions?
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Maybe turn off the approach lights that way they only turn on once car is started?
    calais06's Avatar
    VE Calais MY06
    Jul 2011
    Sydney, NSW
    Quote Originally Posted by pjdm1980 View Post
    Im planning on doing that, but the problem is the low beams don't work at all now lol.
    Any ideas of things to check, or are the gloves/ballasts both dead?
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    What's approach lights? When the lights turn on when you unlock the car? Mine is off, it's the starting process that causes the lights to turn on, off, on, off as the starter motor draws current.
    calais06's Avatar
    VE Calais MY06
    Jul 2011
    Sydney, NSW
    Quote Originally Posted by StoneX View Post
    I would call when you unlock the car and the lights auto turn on approaching lights as you said. I had that on, and then I'd turn my lights off to crank, then back on once the car had started. I think doing this and then sometimes forgetting to turn the lights off has broken either my globes or the ballasts, so I've order a new integrated kit with no messy wires, hopefully they work after that.
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Good luck. I'd have ordered those integrated ones too but they only came in 6000K when I was buying
    calais06's Avatar
    VE Calais MY06
    Jul 2011
    Sydney, NSW
    Oh that's lame.
    My broken ones were 5000K, got the same as you but in 4300K coming in the mail now, guess I'll turn approaching lights off and try to not break this set. I had HIDs in my old car, which outlasted the car so that's why it's a bit disappointing after a few months.
    I know if I did crank with my fog lights on only one would stay on so I'd have to turn them off/on.
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    I got genuine Philips 4300K for my lows and crappy eBay 55W 4300K for my highs, didn't buy the integrated ones because they were only 6000K.
    WL CAPRICE
    Mar 2011
    calais06's Avatar
    VE Calais MY06
    Jul 2011
    Sydney, NSW
    calais06's Avatar
    VE Calais MY06
    Jul 2011
    Sydney, NSW
  15. #15
    calais06's Avatar
    VE Calais MY06
    Jul 2011
    Sydney, NSW
    Can you tell a difference between the eBay and Phillips HIDs?
  16. #16
    lein's Avatar
    lein is offline Comrade Commodore
    VZ Ute
    Dec 2010
    Tropical QLD
    I was talking to a mate yesterday about a similar situation with the headlights. In so far as not coming on until the vehicle is running. What he does is fit a voltage sensing relay (or a programmable relay detecting voltage) and sets them to not turn on headlights until 13V is sensed, and turn off once the vehicle is shut off. This is how he has overcome having lights drawing on the battery while starting. So until the alternator starts to charge your lights don't turn on.
    I aim to misbehave.
  17. #17
    SV6.07's Avatar
    SV6.07 is offline Enjoy it Drive a Holden
    2007 VE SV6 Nitrate & 2011 VE SV6 Poison Ivy
    Oct 2010
    Melbourne,Victoria
    got hid on all lights including the fogs. in my car. had same problem. bought a hid relay and it fixed it the ballasts dont like the auto headlights. seems going by what i found out. the ballasts in hid can be a pain with the auto headlights on the ve. talked to a few guys before had same problem. relay fixed it right away. not hard to install it. the relay i got plugged into my hid lines with no problems and i hooked up the main power line for relay off my positive point where you jump start your car. simple job to do. make sure its a HID relay. not a normal one as most HID relay hook up to your same wiring loom on the hid ballast oh i got mine including the HID from MaxVision. online.
    here is what i asked before from members and they helped
    a question do u have to install a relay on Hid with auto headlights
  18. #18
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Quote Originally Posted by calais06 View Post
    Yeah, the Philips are actually the right colour. The eBay ones in the high beam seem more like 5000K than the 4300K I purchased. I just bought the Philips kit hoping they'd be more reliable/last longer than an eBay kit.
  19. #19
    lein's Avatar
    VZ Ute
    Dec 2010
    Tropical QLD
    Hey StoneX how are the Phillips kits? I'm looking at buying a some to go into a set of Rallye 4000s.
    I aim to misbehave.
  20. #20
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    They work and are the correct colour... That is all so far. I'm just hoping the extra I paid makes them reliable enough to outlast the car. I'd probably just buy cheap eBay ones next time as there doesn't seem to be much difference.
  21. #21
    calais06's Avatar
    VE Calais MY06
    Jul 2011
    Sydney, NSW
    Yeah, I had cheap eBay ones in my last car and it got scrapped and the lights still worked
    Do you think just replacing the ballasts/globes will get my headlights working again lol?
  22. #22
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    It's hard to know... You need a spare ballast and bulb just to fault find the issue.
    I'd just buy a cheap kit and you can always sell it if it ends up not being an issue with your current kit or if you need a part from the new kit, you've then got a bunch of spare parts
  23. #23
    calais06's Avatar
    VE Calais MY06
    Jul 2011
    Sydney, NSW
    I just purchased the HID intergrated kit for the low beams, and 2 new HID bulbs for highs(currently standard globes).
    So I'll replace the lows with completely new, and try to get the highs to work with the old ballasts, then if the ballasts dont work I can just order those aswell.
  1. VP Calais V8 acting weird
    By stockyvrcalais in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-07-2011, 09:02 PM
  2. VN Wont kick over and acting really weird (PLEASE HELP)
    By M3ZZA in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-01-2011, 02:19 PM
  3. 98 VT berlina acting weird..
    By EZ VT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-04-2010, 12:23 PM
  4. stereo acting weird
    By CANYONERO in forum VY Holden Commodore (2002 - 2004)
    Last Post: 26-05-2008, 08:16 PM
  5. Fuel Guage acting weird
    By VLishes in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-01-2006, 08:56 PM
