Results 1 to 3 of 3
Thread: VE Commodore Rough idol when cold
    Vt Executive 5.7ltr 6spd manual
    Jul 2010
    Perth, WA
    Default VE Commodore Rough idol when cold
    Friend has a VE commodore '08' and when first starts it runs really rough. Once she heats up she runs fine if you switch off then back on. But where im lost is something is causing an error for cyl 1, 3, 5 (someone hooked comp upto it) What would cause that ? from what im reading there is soooo many sensors lol. Just trying to help save her some money and see if anyone can shed some light on this Can an oxygen sensor cause this at all ? She had plugs replaced thinking that was the issue, but same thing happening.
    myberlina's Avatar
    myberlina is offline BAD COP! NO DOUGHNUT!!!
    2006 VE Calais
    Aug 2005
    Melbourne, VICTORIA
    That is a strange one. Honestly have no idea myself (i'm not a mechanic).
    But is it possible that there is a blockage on the fuel rail on that side of the motor maybe?
    Alternatively there could be a bit of water corrosion in the wiring loom that services those injectors perhaps?
    Just a few random ideas.
    Ve r8 , VL turbo
    Oct 2011
    Camden
    Have you checked the vacuum lines
LinkBacks (?)
  1. 2003 VY Commodore S pac series 2 rough idle on cold start
    By jdcasagrande in forum VY Holden Commodore (2002 - 2004)
    Last Post: 31-03-2011, 08:17 PM
  2. rough start when cold
    By sirsmokeallot in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-08-2010, 11:08 PM
  3. Rough Idol
    By Casssss in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-01-2009, 03:39 PM
  4. VN SS running rough cold???
    By vnss_1 in forum V8 Development and Modification
    Last Post: 25-11-2008, 07:38 PM
  5. 91 VN Rough Idle When Cold
    By tep_aus in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-02-2006, 07:27 PM
