Page 1 of 2 12 LastLast
Results 1 to 25 of 27
Like Tree1Likes
Thread: 2010 ve sv6 sidi leaking oil?
    ve for lyf is offline Banned
    VE SV6 SIDI
    Nov 2011
    Default 2010 ve sv6 sidi leaking oil?
    hey guys my ve SV6 Sidi 2010 Sedan its a manual the other day i moved the car and found a pool of oil and the dip stick was showing very low oil so I took it to my macanic and we lifted the car and found no oil leaks the only problem there was were thinking if its burning oil? its only got 36,000kms
    what do you guys think?
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Your mechanic probably left the sump plug loose and wasnt about to admit it.
    Silver Certified.
    VE SV6 SIDI
    Nov 2011
    well we lifted the car and looked under there is no oil leaks we topped it up its fine now but what should we do?
    08 VE SS-V 6.0Lt V8 SEDAN
    Mar 2006
    Yes I would firstly check the Sump Plug and make sure its done up reasonably tight.
    Also check the Oil filter and make sure its not loose. If the oil filter is loose, it will leak oil from the seal.
    My previous VY Commodore leaked from the Oil Filter which was a Volvoline Filter, and even after replacing it with a new Valvoline Oil filter, it still leaked.
    Ended up using a Ryco filter and never had the problem again.
    scvs6's Avatar
    scvs6 is offline Donating Member
    1995 Holden VS Berlina 3.8L Supercharged V6 L67
    May 2011
    Ballarat, VIC
    If there was oil on the ground, then it has to be leaking from somewhere. If it was burning oil then there wouldn't be oil on the ground.
    Quote Originally Posted by Jasper44
    For all you kids out there, when your about to have sex, just remember that it would be better if you went out and shot a police officer with a bazooka instead.
    VTSS350 is offline Blown VT LS1 450rwhp
    VTLS1
    Oct 2005
    Quote Originally Posted by superchargedvs6 View Post
    Spot on. Where did the oil on the ground come from?
    VE SV6 SIDI
    Nov 2011
    we dont know all we know is there was oil ont he ground and the dip stick had only a little oil left like you could just see a bit of oil on the dip stick we took it to our macanic and we lifted the car there was no signs of oil leaks anywere we topped it up and its fine now but the car should not of been leaking full stop
    the car is booked in at holden on monday to have a look at everything we just dont get how it happend
    scvs6's Avatar
    May 2011
    Ballarat, VIC
    Quote Originally Posted by ve for lyf View Post
    Yeah your right, if it has got an oil leak then it should be covered by warranty still. Let us know if they find anything.
    VE SV6 SIDI
    Nov 2011
    yeah I will im worried about leaving car at holden because last time i drove past the holden guy took a maloo ute out and full put hes foot down hopping they dont do that to mine
    scvs6's Avatar
    May 2011
    Ballarat, VIC
    They shouldn't be allowed to do that. Only problem I had with Holden was when I took my Statesman there to get the reverse sensors fitted. When I got it back they changed a radio station and turned the bass level up, so they were messing around with the stereo a bit.
    VTLS1
    Oct 2005
    scvs6's Avatar
    May 2011
    Ballarat, VIC
    Quote Originally Posted by VTSS350 View Post
    Big deal, the cars are fine to do that with.
    He obviously cares about his car (like I do), and doesn't want people thrashing it around. I'd be pretty pissed off if someone did that to one of my cars when theres no need for it.
    Ve Sv6
    Sep 2008
    Shepparton
    Yes they can get in big trouble if caught doing that....however it is possible it was the drivers Maloo...still not good practice in front of customers
    VE SV6 SIDI
    Nov 2011
    bro what you on about a car is a car if you pay 40k for a car ITS MORE THEN A car and you should respect it my Car is very important to me and I will always look after it
  15. #15
    VE SSV
    Mar 2010
    How can you have a pool of oil then jack it up and find nothing not even a drop i think you are the same guy having a lend of bulls$$t posts get a life you are a waste you have a trademark what you say on your posts and YOU always create new nicks thats why you always have a minimum amount of posts BUSTED
  16. #16
    VE SV6 SIDI
    Nov 2011
    Hahahahha oi mate get you facts right first you jump to conclusion i was looking online for help and i found this site so i decided to post and see we have never had this problem with our ves befour and now we do it is booked in holden for tuesday im dropping it of tonight if i get a sheet from them proving the had the car i will upload it to this post to prove you wrong stop being a sm@art @zz
  17. #17
    VE SV6 SIDI
    Nov 2011
  18. #18
    VE
    Mar 2011
    n
    Well, he could try, but he sure as feck will not be hopping your SV6....
    HIDs.....LEDs..... DRLs..... CHEV Badges..... ->
  19. #19
    VE SV6 SIDI
    Nov 2011
  20. #20
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Use your browser's spell checker so you don't look like a spastic.
    Pretty sure your answer is in post #2
  21. #21
    VE SV6 SIDI
    Nov 2011
  22. #22
    jamesmp's Avatar
    jamesmp is offline The Photo Journalist
    MY10 VE Commodore SV6
    Dec 2010
    Brisbane, QLD
    My MY10 VE SV6 burned quite a but of oil up to about the 30,000 mark. Seems to be a common problem that fixes itself. Just keep a good eye on your levels.
    I am here: http://maps.google.com/maps?ll=-17.744177,168.319215
    My portfolio at RailPictures.Net!
    My portfolio at Flickr!
    This reply is intended to provide general information only, without taking into account any member's personal circumstances.
  23. #23
    VE SV6 SIDI
    Nov 2011
    yeah holden found no oil leak or nothing wrong with the car were just woundering why the oil was on the floor and why the oil was 0 to none
  24. #24
    VE Calais-V 6.0L
    Aug 2005
    Hastings
  25. #25
    VE SV6 SIDI
    Nov 2011
    why would you do that mate? I still dont get why the oil in the car was like empty and they found no leaks
  1. Top of Rear Passenger side leaking Leaking
    By Holden=#1 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 29-10-2010, 10:23 AM
  2. New 2010 SV6 SIDI
    By The X Man in forum VE Holden Commodore (2006 - ?)
    Last Post: 11-05-2010, 05:35 PM
  3. 2010 SIDI VE SV6 ute engine mods
    By Dimi in forum VE Holden Commodore (2006 - ?)
    Last Post: 11-03-2010, 03:17 PM
