Results 1 to 6 of 6
Thread: check system error??? help!
    VE SV6
    Nov 2011
    Auckland, New Zealand
    Default check system error??? help!
    Hi guys,
    Was driving my VE sv6 today and suddenly the engine illumination picture appeared on my dash and it said 'check system'. I pulled over... Turned the car off then started it again. Moments later it did the same thing except when I put load on the car or put my foot down slightly the car started to jerk like it was struggling. No unusual noises were made it just felt like it was struggling and developed that jerking feeling. Lucky I wasn't to far from home and came home real slow. Does any one have any ideas as to what this is or what is causing it and how I fix it?
    Any help, cheers
    Holden VZ Acclaim Odyssey Blue
    Aug 2011
    did the light for check oil come on it think the system just turn car of and restart it should go back to normal
    Supe's Avatar
    Supe is offline Supe
    VE Calais 6.0
    Jan 2008
    Rural NSW
    Could be a million things, you'll have to get the error code checked. Possibly bad fuel or fuel pump on the way out though based on the jerkiness.
    VE SV6
    Nov 2011
    VE SSV Manual
    Oct 2011
    Mandurah
    Disconnect the negative lead from your battery for a minute then connect it again... Take it for a thrash and see if you can replicate the fault..
    VE SV6
    Nov 2011
    Thanks for that. Had it at dealers today. They reckoned 6th cylinder was misfiring due to shitty plug and a little bit of water present. Running smooooth as now!
  1. (VR) did error check car wont start
    By two-bit in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-06-2011, 03:16 PM
  2. I did an Error Code check and got a few codes, so what do I need to replace?
    By hsv91ss in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-11-2010, 07:53 PM
  3. how to check error codes on a wk v8
    By alienn in forum VY Holden Commodore (2002 - 2004)
    Last Post: 07-10-2010, 07:55 PM
  4. check power train error coming on when given it some stick
    By mattyr82 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 19-09-2010, 11:17 PM
  5. How do i perform an error code check?
    By vs_commy5506 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-06-2009, 04:26 PM
