Results 1 to 14 of 14
Thread: Grounding Point for Amps in the VE
    VE SV6 SERIES 2
    Jun 2011
    Kearns
    Default Grounding Point for Amps in the VE
    Hello peoples,
    Just wondering where most people who have an amp (or 2) in their boot ground their amps. I have chosen to use the seat backrest bolts but not sure if this is a good place to do it or not.
    VY Berlina V6 / R31 Skyline
    Dec 2008
    Any point which is sanded back to bare metal will suffice. Make sure you use a good solid bolt and tightly crimped lugs on the ground cable(s)
    Quote Originally Posted by xVisions View Post
    driving without a license at the moment, My vl has beaten every single car I've street raced!!
    06 vz sv6
    May 2011
    south east sydney
    Mate the best earthing point is back at the battery but as sweefu said any point sanded back to bare metal will do..
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    itsArthurKomar is offline sexy beast
    super awesome time machine
    Apr 2011
    ya asss
    y do people even think of groundin the amps on the chasis in a ve? theres a battery literaly 1 meter away from it ####
    Brunette, 5-10', 10D's, great personality
    Nov 2003
    The recommendation is always to have the earth as short as possible, preferably less than 30cm to, as said above, a sanded back clean bolt, screw or nut. Saying that, I mounted my amps in the well wheel and ran my 0g ground back to the battery at a length of around 70cm and have had no issues with noise or performance. Dealers choice. What ever you add in ground cable from amp/s to chassis .ie 0g or 2x 4g I would add to the earth of the battery to chassis for peace of mind.
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Quote Originally Posted by raff View Post
    People say that the ground cable should be as short as possible but I don't see why. As long as the ground cable is adequate size for the current it will be flowing then it can be the length of the whole car, if you wanted. Grounding to the chassis is just done to save money on cable.
    Last edited by StoneX; 23-11-2011 at 01:35 PM. Reason: Added quote to avoid confusion
    Apr 2011
    ya asss
    Quote Originally Posted by StoneX View Post
    yeah i know that but just if u got a ve y not just spend that xtra money on some extra leng insted of sanding back the paint and leaving it open for rusting and corrosion .... lol
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Quote Originally Posted by itsArthurKomar View Post
    I was the person who said ground directly to the battery and my comment you quoted is supporting that too
    Nov 2003
    I dont think a short ground is to save money! It generally is to prevent the chance of noise into the system. The longer the ground run the more resistance and more possibility that it could draw interference from other power source or devices within the car, the same concept as keeping RCA length as short as possible. More than likely it may make little difference but saving money on cable and less chance of noise is a win win.
    And regarding sanding back to bare metal and corrosion, I always paint a metal primer over the small area sanded back once the bolt/screws and cable have been connected. Takes two seconds!
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    The power cables won't pick up interference (even if they did, the amplifiers PS would filter it out), they cause interference to RCA's. If power and RCA are kept separate, like they should be, then you should not pick up interference.
    VE SV6 SERIES 2
    Jun 2011
    Kearns
    My original post was to see where people who are VE owners have grounded their amps. The battery is obviously the clear winner here but I haven't used it because of the extra length in cabling that is required, only because most people say that the shorter the cable the better. If this doesn't matter then I'll probably go the way of using the neg terminal of the battery and be done with that. I am also using 4g cable for the earth.
    And before you all ask.....yes, I am getting alternator whine at the moment which is really starting to get to me. Very faint but still annoying. I know that this is not only caused by the grounding point but certainly could be the issue. I also have another amp grounded at a different point.
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    If you used a high level to low level converter for the sound, these often induce engine whine.
    VE SV6 SERIES 2
    Jun 2011
    Kearns
    Nope, I had the RCA mod done by Greg.
  1. M7 and M5 point to point speed cameras
    By Pete SS in forum The Pub
    Last Post: 23-10-2009, 01:44 PM
  2. Grounding Kit
    By tiersum in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-03-2009, 06:41 AM
  3. New Speed Cameras - Point To Point
    By jaskel in forum The Pub
    Last Post: 16-10-2008, 08:58 AM
  4. VT Cambering? 4 point and 2 point
    By raZel in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-04-2007, 08:55 PM
  5. Grounding point for H/U in VT??
    By dbun in forum Car Audio
    Last Post: 08-07-2006, 01:18 AM
