Results 1 to 9 of 9
Thread: VE GTS hard to start after long drives (one hour plus)?
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Default VE GTS hard to start after long drives (one hour plus)?
    My GTS has all the mods you see in my signature below and lately it's been hard to start after long drives. It has dual fuel and was thinking the petrol pump might have started to let go but the other day a mechanic told me (he didn't want to touch it because its been tuned) the car might be searching for the MAF sensor (as its had a MAFLESS tune), any ideas before I take it back to the tuners?
    Cheers Pat.
    07 VE SV6
    May 2010
    Gold Coast QLD
    have u checked for any codes? or mechanic checked? does it crank alright? just doesnt fire? just to make sure, u've had a MAFLESS tune and unplugged the MAF sensor?
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Yep it's got a cold air intake. It cranks for 5 seconds then fires over but on short trips it's fine, haven't checked for codes the mechanic said to just take it back to the tuner he didn't want to touch it.
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Make any difference on gas or fuel or same cranking time on both?
    Silver Certified.
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Car only starts on petrol then 50 seconds later switches to gas.
    TrikkBen's Avatar
    TrikkBen is offline Compulsive.
    BNR32
    Apr 2009
    SE, Vic
    ........ Stupid post.
    There is no such thing as stupid questions, Only stupid people.
    VE GTS
    Apr 2005
    How did you go with this?
    mines done it from day one with JTG and i have a cam in mine. cranks for a bit then fires. only happens intermintantly though. as you said mostly off a long run, let it sit for a bit then try and start it. been to other tuners and no joy, also have dual tables enabled didn't make a difference. no big issue just really wanted to know what it was.
    Hunter SS's Avatar
    Hunter SS is offline Growing Old Disgracefully
    2006 VE SS
    Mar 2009
    Upper Hunter Valley NSW
    Mine has done the same thing from time to time, even before i had it tuned or before i put the CAI or exhaust.
    Reviled did i live as evil i did deliveR
    • UNDERSTEER is when you hit the wall with the front of the car.
    • OVERSTEER is when you hit the wall with the rear.
    • HORSEPOWER is how fast you hit the wall.
    • TORQUE is how far you take the wall with you.
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    On longer trips, the fuel in the rail could be getting hot and vaporising out of the line, so when you go to start it there's no fuel in the rail and the pump has to fill it again before it'll fire. Try cycling the key a few times before starting next time and see if it makes a difference.
    May depend on the gas system, a good system should switch off the fuel pump while on gas.
  1. Taking a bit long to start
    By ice_cold17 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-09-2011, 08:35 PM
  2. VT V6 taking a long time to start
    By V-ahhh in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-10-2010, 06:28 AM
  3. Hard restarting VR...1 hour wait.
    By Hotblooded_VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-04-2009, 07:00 PM
  4. taking a long time to start up
    By Jenkies in forum VY Holden Commodore (2002 - 2004)
    Last Post: 11-11-2008, 10:01 PM
  5. Things that cause a VT to take a while / too long to start
    By jazza15 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-07-2008, 08:39 PM
