I got a 2010 VE SV6 and I baught VE SSV Leather seats can someone give me directions on how to put them in?
The Back seats are prety easy start with the long section that u sit on Pull it up its cliped in with one clip on each side when you pull that of theres two blots on each side of the rear seats on the bottom undo those and lift the seat up its cliped from the back of it, front sears teres two bolts on the back of each seat, undo those and lift the seat and tilt if forword it will come out youl have to be carful with unpluging air baggs.
^^ Faark me, that was hard to read!
rekon you could come help me
Just undo as many bolts as you can find that look like they will remove the seat,on front there should be 2 on each slide rail.Give it a go and dont worry about the knob heads here.
AND WHERE CAN I BUY THIS HEADLIGHT FLUID? IS IT WHITE AND STICKY AND DRIBLLING DOWN YOUR CHIN?
