Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By peterrobo
Thread: Please Help! Unsolved Misfires in Cyl 2, 4 and 6
    2006 VE SV6
    Nov 2011
    Numurkah VIC
    Default Please Help! Unsolved Misfires in Cyl 2, 4 and 6
    Hi all,
    Not long ago I posted a thread regarding random misfires in cylnders 2,4 and 6 in a 2006 VE SV6.
    Since then the car has been in and out of my mechanics but nothing has been found, and theres reasons for that.
    The random misfires come and go. It seems as tho every time I take it to the mechanic it stops misfiring. When my mechanic plugs is scan tool in it still reads 4 codes;
    P0300
    P0302
    P0304
    P0306
    Allthough it is not misfiring at the time.
    Since then he has not had time to look any further, So I have been reseting the computer by disconnecting the battery just to get around. It will run fine for 3-4 days with not a single hiccup after disconnecting the battery and then all of sudden (like clock work) start misfiring with CEL and running really ruff. The only way I can get it to stop is to disconnect the battery again.
    It only seems to start misfiring after 3-4 days of normal driving and when I come to a traffic light when I stop and sit on idle. So it seems as though stopping at a traffic light or stop sign when at idle triggers the problem after 3-4 days of driving.
    Does anyone have any Idea wat is going on, I tired of carrying a 10mm socket to disconnect the battery just in case it starts playing up.
    Hope this makes sense.
    Would really love some help, so throw some ideas and experience this way! PLEASE
    Ve Sv6
    Sep 2008
    Shepparton
    Well the best way to start with misfire problems is change the spark plugs...and see if you can check the coil packs......misfires are usually something minor like that rather than massive problems. i'd be looking there first, have you changed the battery?
    VE2 SV6 SPORTWAGON
    Feb 2006
    SA
    2006 VZ Calais 190kw
    Aug 2007
    Engadine NSW
    Because your problem (according to the fault codes you've given) appear to be restricted to the passenger side bank of cylinders (ie: 2, 4, & 6) I'd be looking at a dirty or corroded electrical connection on that side of the engine. If you've washed your engine down and haven't blown out all moisture it could also be moisture build-up in the spark plug cavities causing a short and misfire. Certainly check all electrical connections are clean and dry for the fuel injector harness as well as the coils that you have easy access to first. If you succeed in reducing the error codes you're well on the way to resolving the issue.
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Failed catalytic convertor is a common cause of misfiring on one bank.
    Silver Certified.
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    Maybe your alloytech thinks it has AFM.
    More likely what peter said, something to do with the passenger side. Is there a seperate power lead to each bank, or earth or fuel rail or faulty 'ECU' ? Next time its running well after you reset it try jiggling all the wires n jazz you can find on that side and see if you can trigger it..
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Try checking the earth aswell, which is down below the coilpacks, on the side of the head.
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    2006 VE SV6
    Nov 2011
    Numurkah VIC
    Thanks for the replies guys.
    I will certainly try everything listed here.
    Other people have been throwing the words 'Fuel Pump'????
    Is this possible? I spose they are my computerized now and the fuel pump could be failing with its electrical side of things
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Aug 2007
    Engadine NSW
    Hey jboz1992, did you get a resolution to your problem yet? If so, what was the cause of the problem as I'm sure many on here would like some feedback.
    VE Omega
    Nov 2010
    Given that it runs properly after every reset, it might be a computer/sensor/monitoring related problem, especially given that the problem returns like clockwork once the computer leaves its closed loop parameters and starts 'tuning' itself. Rule out all the the common options between the two banks eg Fuel pump, maf etc and that leaves things bank specific things like 02 sensor, cam angle sensors, cam angle actuators, cat converter etc, maybe knock sensors (its has 2, not sure if it uses 1 for each bank, or both for both banks).
    I just had a totally different problem where everything would run properly after a reset for an exact amount of time:
    Ghost in the dash computer (fuel injector problem)!
    My 2 cents anyway hope it helps.
  1. VS V6 Excesive fuel usage and strange misfires when moving slowely forward in gear.
    By hsv91ss in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-08-2011, 07:59 PM
  2. Unsolved noise problem
    By Nagwash in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-08-2010, 07:19 PM
  3. Engine Misfires or doesn't wan't to start from time to time
    By redlion05 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 01-07-2010, 01:57 PM
  4. vr v6 5 speed misfires
    By vr5speed in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-09-2008, 10:55 PM
Tags for this Thread
