Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By s_ikari2015
Thread: Fluted Bonnet
    VE Omega - SS Mock Up
    Feb 2011
    Default Fluted Bonnet
    I recently bought the hsv bonnet to go with the pontiac front end conversion. i was just wondering if it is possible to make the two air intakes on the bonnet part of the air intake system so that they are a functional part of the car instead of a cosmetic feature.
    cheers
    VE2 SV6 SPORTWAGON
    Feb 2006
    SA
    anythings possible, just a matter of how much you want to spend fabricating it up. Just have to work a 2 part system where the bonnet opens/closes onto & seals around the intake mounted in the engine bay
    The Mad Dutchman
    Feb 2011
    VE2 SV6 SPORTWAGON
    Feb 2006
    SA
    no, as i am sure but someone may correct me that this hasn't been attempted before.And to workout how to stop water ingress.
    The Mad Dutchman
    VE Series II SS-V Redline Sportswagon A6 Phantom
    May 2011
    Shellharbour
    Default would it be worth it?
    Quote Originally Posted by captaincupcake View Post
    cheers
    Where the flutes are is right above the throttle body(one each side) so from there you would have to run your intake connection from these(have a panel filter straight below the flutes with some sort of compression seal to seal the gap when the bonnet is closed) back towards the front of the car and and you would need to turn it around again to get into throttle body, so it would kind of be an S bend or a bad U bend at least, pretty sure that you would get more benefit from a normal OTR (over the radiator intake). If you are leaving the MAF in place this becomes even harder (the S bend). Or if you were thinking of routing the flutes to the standard air box I think you may go backwards in performance or a minimum change. Pretty sure the VZ Pontiac GTO (I think it was called) had the flutes plumbed some how to the intake so you might want to check up on that, I know the Manaro didn't have this but the American version apparently did.
    Feb 2011
    alright thanks ill do some research. im real keen as this would be a unique this but also i would like the flutes to be functional. if i was to make this happen, where would i go to have this work done?
    s_ikari2015's Avatar
    s_ikari2015 is offline Fun IS easier with an 8
    '02 Monaro V2 CV8 6m
    Nov 2007
    Australia
    Default Ram Air Intake
    You want to look up Ram Air Intakes.
    Capa...
    Corvette style twin to single.
    You could even consider modifying it instead of having twin tubes have a shortened OTR style panel filter. By having the flutes unblocked would then allow more air to channel down into the tray. Would be better than just OTR. Might look at this for myself actually.
    I haven't lost my mind, it's backed up on tape somewhere
    Feb 2011
    will a v8 otr fit on a v6 ?
  1. VZ Fluted guards question
    By lastlegend in forum VY Holden Commodore (2002 - 2004)
    Last Post: 27-04-2011, 12:24 AM
  2. [QLD] VX VZ ss fluted guards -f/glass -Gold Coast
    By lifeguard_aus in forum Parts And Other Items For Sale
    Last Post: 02-03-2011, 11:37 PM
  3. Fluted Bonnet for VY Monaro?
    By RicheCV8 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 21-07-2010, 10:14 AM
  4. VZ Fluted guards on a VY SS
    Last Post: 27-02-2009, 08:03 PM
