Results 1 to 13 of 13
Thread: ve ss temp guage not working
    ve ss ex cop
    Jul 2011
    Default ve ss temp guage not working
    Hi just wondering if anyone else has had this problem with there ve ss. The temp guage just stop working today, went into engineering mode and tested dails which are all working fine, coolant temp read 0 degrees but. Aircon seems to have stopped working to.
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    Sounds like you've got a problem with a module locking up the CAN BUS line, need to have the trouble codes checked and work out which ones giving you trouble
    Sent from my MB860 using Tapatalk
    ve ss ex cop
    Jul 2011
    Not to sure what CAN BUS line is, does that just mean they change the codes in computer at holden dealer?
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    The Can bus is the data network that all the modules in the car use to communicate. In VE's theres a low speed network for comfort items such as HVAC, Radio etc and a high speed network for engine/ABS/ESP etc.
    It may simply be a failed temp sensor. Ill check out the schematic and get back to you.
    Silver Certified.
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    The IPC displays the engine coolant temperature as determined by the engine control module (ECM). The IPC receives a GMLAN message from the ECM indicating the engine coolant temperature. The IPC engine coolant temperature gauge only displays coolant temperatures greater than 60°C. The engine coolant temperature gauge defaults to 60°C or below if:
    • The ECM detects a malfunction in the engine coolant temperature sensor circuit.
    • The IPC detects a loss of GMLAN communications with the ECM.
    • The body control module (BCM) detects a loss of GMLAN communications with the ECM.
    Basically the sensor itself may have failed, or as said above a loss of comms. Need to check DTCs with a scan tool.
    Silver Certified.
    ve ss ex cop
    Jul 2011
    Thanks heaps for the info not under warranty so hope holden doesnt screw me to hard on the fix!
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    ve ss ex cop
    Jul 2011
    ve ss ex cop
    Jul 2011
    Well i just had to move my car to let someone out the driveway and the problem seems to have vanished, aircon back to freezing cold and temp guage back to normal service warning gone from dash to.?.?
    VE Calais International
    Dec 2011
    Aldershot
    Hi there,
    Had the same thing happen to my Calais this morning. Have checked all fuses and relays and all seem fine. Im hoping that mine will start in the morning and the problem will be gone.
    Dec 2011
    Aldershot
    Hi just for info, my calais had reset its self over night and no problem since.
    vl
    Apr 2011
    brisbane
    Pontiac GTO & Chevy Lumina SS
    Oct 2011
    Kingdom of Bahrain
    '07 Lumina SS (in Bahrain)...I've been having the same problem off and on for the past couple of weeks. The "Contact Dealer" message displays, then my A/C and temp guage stop working. After driving for a while and (sometimes) after sitting over night it goes away and everything is fine. Had it in the dealer last week and, of course, it wasn't malfunctioning and they didn't know what I was talking about.
    2004 (QSM M6) Pontiac GTO - Holden CV8Z Conversion
    2007 (QSM M6) Chevrolet Lumina SS - soon to be - Holden VE conversion (I hate the gold Chevy emblems and so does the wife )
  1. ok need serious help now temp guage
    By Duncs_VQ-3800 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-08-2011, 05:42 PM
  2. temp guage not working
    By Jamie-b in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-11-2009, 11:18 PM
  3. O2 Sensor & Temp Guage Not Working
    By Karsten in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-08-2009, 02:29 AM
  4. Temp guage not working?
    By Razor- in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-08-2009, 01:11 AM
  5. Fuel gauge and Temp guage are not working...
    By nilprapai in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-12-2008, 01:11 PM
