hey all, has any one had a problem with no compression in cylinder 2 i have checked timing and that is not the problem. im really just after a heads up if any one has had this problem as well.... its a 08 berlina.. ty alll
If you have No Compression in a Cylinder, you have either broken a valve spring, or a bad blown head gasket, or something more major like a cracked head. Also could be a loose spark plug. I would check the spark plug 1st (Obviously if youve done a compression test, the spark plug should not be the prob. Then Valve springs 2nd. Pretty hard to say unless you get it checked out.
