I've got a couple of quotes but they vary a fare bit and I'm not quite sure if some are to cheap/expensive so here goes, the quotes all involved the following work
- Cam
- Lifters
- Dual row timing chain
- Shaved heads
- Double row timing chain
- Tune
and the quotes ranged from $4600 to $5700 does that sound about right?
I'm open to all opinions/feedback, and I plan on booking it in next week or so.
Not sure if I've put this the right section but if I haven't then I'm sure someone will move it.
that seems about right it will vary abit depending on what brand parts they are using
2002 HSV GTO COUPE
VK calais ls1 turbo conversion (in the build)
2009 turbo v8 landcruiser
My VK http://forums.justcommodores.com.au/...-vk-355-a.html
cam package that includes double row chain, springs, retainers and lifters is about 1500 in parts then the tune about 1k. fitting the cam pack about 1k then the headwork i'm not 100% sure lol so it all seems about right to me
Those prices sound fair.
With the work you want to do, I would be more than happy to pay a few hundred dollars more knowing I'm taking the car to a place with a good reputation.
I'm getting a 3000RPM stall as well so now just to find the right spec cam but it won't be happening till after Xmas as the shop is shutting down for the holidays and is booked out till then.
im out of my mind at the moment...please leave a message
I'll get it changed while they're at it and check the size of the cooler when I'm down there next, it has 3.7's from the factory.
Going by this web page-
http://www.carbuddy.com.au/car/value...5&tid=99939030
auto is a 3.7 and the manual is a 3.27?
You are correct, it does say that. Unfortunately they are wrong lol.
*edit*
I will elaborate a touch.
HSV use both the 3.27 and 3.7 for auto and manual transmissions respectfully. The part number's are common GM part number's 92223668 (3.27) and 92223667 (3.70).
In the VE series, differential breakdown for V8's are:-
Commodore:
2.92 for auto
3.45 for manual
HSV:
3.27 for auto
3.70 for manual
heard a rumor some HSV's are 3:45 auto and 3:9 manual.
rumor not fact I dont know what model or anytihng
