Results 1 to 3 of 3
Thread: Ve Engine temp
    Ve SS Ute
    Sep 2011
    Default Ve Engine temp
    Hey all,
    Just got my ve ss ute back from the panel shop as it got hit in the front. I had a new radiator fitted and my engine temp seems to be sitting a bit high was wondering what other peoples cars sit at normal so I can compare as I cant remember
    what my car use to sit at before the smash.
    It is currently sitting at normal operating temp in between 1/4 and 1/2 on the gauge is this normal?
    UFO's Avatar
    UFO
    UFO is offline I Believe
    MY10 VE Sportwagon SIDI 3L
    Oct 2009
    spot on.
    mines always under half, and if its ever over half you should be keeping a closer eye on it. all my previous cars behaved the same way.
    MY 9.5 SSV Sportswagon M6 & 08 prado D4D GXL M6
    Nov 2005
    Bushfield, Vic
    Make sure it has no air in the cooling system, this can happen if not bled and cause the car to run hotter. I always use a empty 2 litre plastic milk container or similer cut the bottom out of it put in top of radiator and fill it up so the coolant is higher than the engine. VZ's and VE's don't have a bleed nipple so this option works well.
    [CENTER][URL="http://forums.justcommodores.com.au/showthread.php?p=490264#post490264"]
  1. Engine oil temp?
    By Gambel in forum VE Holden Commodore (2006 - ?)
    Last Post: 04-02-2011, 05:05 PM
  2. vs v8 engine temp
    By cannibalrikman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-12-2010, 04:16 PM
  3. gauges oil temp and engine temp
    By vzon20s in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 24-11-2008, 05:31 PM
  4. engine temp
    By gungazza in forum VL Holden Commodore (1986 - 1988)
    Last Post: 08-10-2007, 06:36 PM
  5. How HOT is HOT when it comes to engine temp??
    By futronix in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-11-2005, 11:06 AM
