Page 1 of 2 12 LastLast
Results 1 to 25 of 31
Like Tree10Likes
Thread: ve sv6 ultra low. Do you need shocks??
    08 VE SV6
    Jul 2010
    South Eastern Suburbs
    Smile ve sv6 ultra low. Do you need shocks??
    Hey guys,
    Want to lower my VE. Goin for that sacked look at the back. so im planning to go ssl fronts and sssl rears. Just wondering whether you need shocks initially? cos im low on cash atm. Anyone know what i should be paying for the 4 springs and labour.
    Appreciate the help,
    Indyy
    ssv ute
    Nov 2011
    EBAY, should be able to pick up a set for $220. Unsure about the labour prob couple hundred or do it yourself. Its not that hard Just remember to get a wheel alignment after. As for the shocks if ya low on cash keep the same ones till they wear out, but it will save one the long run doing them all at once
    08 VE SV6
    Jul 2010
    thanks for the quick reply mate.. one more question
    how long will the stock shocks last?
    thanks again
    TinSnips's Avatar
    TinSnips is online now Polish all the things...
    VE SS Ute M6
    Mar 2010
    Hills District, Sydney
    Not very long. And something to keep in mind is that when you lower a car but don't change the shocks, you lose part of the travel of the shock absorber - so if it bottoms out (it will) you effectively lose traction to that wheel. I lowered mine and kept the shocks - will be binning the stock shocks ASAP. Big mistake not to change them at the same time.
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Dont phuck around, your suspension and tyres are what keep you on the road.
    Fit the correct shocks for the springs.
    Silver Certified.
    TrikkBen's Avatar
    TrikkBen is offline Compulsive.
    BNR32
    Apr 2009
    SE, Vic
    Lowering any VE is illegal unless you can prove the ESC has been re-calibrated to work with the different geometry.
    Thanks Reaper.
    Ben
    There is no such thing as stupid questions, Only stupid people.
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Quote Originally Posted by TrikkBen View Post
    Thanks Reaper.
    Ben
    Never heard of anyone being defected because they couldnt prove the ESP had been calibrated LOL. You get defected because the car is below the legal height limit. How do you propose one recalibrates the ESP?
    ESP works off wheel speed sensors and yaw rate, ride height is irrelevent. You lower the car, the EBCM still calculates from ride height and yaw rate. If the car responds differently due to firmer suspension the EBCM simply adjusts accordingly.
    Silver Certified.
    TrikkBen's Avatar
    BNR32
    Apr 2009
    SE, Vic
    Quote Originally Posted by RiCeY View Post
    Exactly.....
    For those in Victoria wanting to slam their VE (or even slightly lower it :))
    Explain your dribble to Vicroads.
    Jan 2008
    NSW
    My standard shocks lasted for 3 years after i lowered my car. And that was only the rears, fronts are still going strong.
    And when i changed them I just went with standard KYBs. My car is quite low and the ride is still beautiful.
    Its one of those parts where the 'if it ain't broke don't change it' rule comes into play.
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Just because you lack the intelligence to comprehend what I say doesnt mean its dribble.
    Silver Certified.
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Quote Originally Posted by WPN-42L View Post
    Maybe if youre an idiot. So going by your logic I fit a LS9 to my car but dont fit better brakes because "they aint broke".
    You change the springs dramatically ie the op going for SSSLs, you also fit the appropriate shocks. Its common sense.
    Silver Certified.
    TrikkBen's Avatar
    BNR32
    Apr 2009
    SE, Vic
    No, it's no that all. It's dribble because I don't really care what you have to say, either way I'm right.
    ssv ute
    Nov 2011
    Quote Originally Posted by indayy View Post
    thanks again
    Probly not long. but in my last ride I had the same set up and they lasted for three years ( and was rough). But, if your going that low I probly would Change the shocks straight up as they are a bitch to change your self!
    Jan 2008
    NSW
    How many times have you heard of shocks failing due to upgrading to lowered springs?
    Maybe if you could read properly you'd be able to understand the first part on my last sentence.
  15. #15
    UFO's Avatar
    UFO
    UFO is offline I Believe
    MY10 VE Sportwagon SIDI 3L
    Oct 2009
    Dude, I'm sorry but I completely disagree.
    Buying replacement standard shocks for a car that is "quite low" is a mistake. You may find the ride 'beautiful', but it wouldnt be close to what it's actually capable of.
    Load up your lowered springs around a corner that is just a little bit bumpy, and then push a little more and you'll very quickly see how unstable stock shocks are with lowered springs. They just dont work the way they are supposed to, and youre kidding yourself if you think they do.
    Lowered springs have a higher spring rate to compensate for the less room they have to travel than standard springs. Accordingly, the shock absorber needs to be 'tighter' to dampen the bump and rebound properly. Not only does the shock need to be a different spec, it needs to be shorter... because again, the operating range of movement is not going to be where the shock manufacturer designed it to be (the movement will be shorter and harder, and there's increased chance of actually hitting the bumpstops as you go lower and lower in ride height). Stock shocks are too soft for lowered springs.... plain and simple. Yeah they'll be fine for 95% of your daily driving, but push around a corner too hard on even slightly unstable surface and you'll quickly see how important that 5% is.
  16. #16
    UFO's Avatar
    UFO
    Oct 2009
    It's not a matter of failing, its a matter of not working as they should.
    They arent going to fall out of the car, but handling will most definitely suffer.... and that's when things can go from bad to worse.
    Proper shocks matched to the new springs might save you the stained undies of losing control in the first place.
  17. #17
    Troy711's Avatar
    Troy711 is offline Moderator Puppeh
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    Wtf? No wonder people call the current generation of kids/teens brain dead when they say stupid shit like 'sacked'.
  18. #18
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    In your own mind. But you continue living life being scared to do any modifications because in reality they are all illegal.
    Silver Certified.
  19. #19
    TrikkBen's Avatar
    BNR32
    Apr 2009
    SE, Vic
    You argue that it's not illegal, then you tell me they're all illegal. Make up your mind.
    You continue living your life as a douche..
  20. #20
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Ahh me keyboard warrior.
    Where did I say it wasnt illegal? I said I had never heard of anyone being done for that reason and that you cant recalibrate the ESP so your whole arguement is pointless.
    I live my life using logic and common sence, not being a scared little faggot like yourself who shits bricks at every piece of legislation passed by our incompetent government.
    Silver Certified.
  21. #21
    astroham is offline PHATV6
    SIDI sv6
    Jan 2010
    Penrith
    Lol troll ...
    As for the shocks ... Probably a good idea to change them ssl front isn't too bad but the sssl in the rear is pretty low ... I jaw the same size and I'm glad I changed mine ... Just don't buy shitty shocks like munroe or something
    2010 SIDI sv6 ... 180atw ... more to come
  22. #22
    vs clubsport
    Mar 2009
    brisbane
    I'm also about to lower my VE ! I was going for sl or ssl "see how much room i have when the 22's get fitted" all around but I have a Calais v with fe2 suspension.
    Do you guys still think it is req to get shortened struts and shocks even with the fe2 suspension?
    Cheers Doug.
    Float like an elephant sting like a tree clubsport hits what doug does'nt see
  23. #23
    TinSnips's Avatar
    VE SS Ute M6
    Mar 2010
    Quote Originally Posted by clubby_you View Post
    Cheers Doug.
    Assuming you keep the correct rolling diameter with your tyre (which you can't do legally in any way with 22s, incidentally) - you'll have pretty much the same amount of room as you do with your stockies. The inside bits change, the outside stays the same. The idea of 20s filling the guards better in profile is a visual thing, rather than the wheel and tyre actually taking up more space. The only thing that may or may not impact 'space' is your offset or width - which you should have a pretty good idea of before buying the wheels.
  24. #24
    vs clubsport
    Mar 2009
    brisbane
    Quote Originally Posted by TinSnips View Post
    Assuming you keep the correct rolling diameter with your Tyre (which you can't do legally in any way with 22s, incidentally) - you'll have pretty much the same amount of room as you do with your stockies. The inside bits change, the outside stays the same. The idea of 20s filling the guards better in profile is a visual thing, rather than the wheel and Tyre actually taking up more space. The only thing that may or may not impact 'space' is your offset or width - which you should have a pretty good idea of before buying the wheels.
    Umm ok ... you kinda just contradicted yourself in saying the wheels are bigger then stock overall diameter
    but dont effect the clearances when lowering ...anywayyyyy ..
    I would like to know if the fe2 shocks/struts are more suited to lowering opposed to the standard suspension ?
    Cheers Doug
  25. #25
    TinSnips's Avatar
    VE SS Ute M6
    Mar 2010
    ??? what contradiction? Wheels size goes up, tyre profile goes down - so the rolling diameter, the outside bit of the tyre, is the same - whether you have 18s,19s, 20s, etc. It legally has to be the same, so that your speedo isn't out. So no change in clearance between tyre and guard - like I said, it's not unless you're changing offsets or widths that it can become an issue.
    FE2 struts are suited to FE2 springs - they're not short shocks, so if you're lowering, you will bottom out (I have FE2 shocks with pedders springs and it's rubbish) - FE2 shocks are also matched to the spring rate of the FE2 springs - not the higher spring rates of aftermarket springs.
  1. [VIC] FS: KING SPRINGS! Front super lows + rear ultra lows + monroe shocks all round
    By Patti2912 in forum Parts And Other Items For Sale
    Last Post: 10-04-2012, 01:27 PM
  2. Shocks to suit Ultra Low Springs...suggestions?
    By MR 1JZ in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-10-2011, 05:32 PM
  3. VS Gabriel Ultra Rear Shocks
    By NVE_069 in forum Parts And Other Items For Sale
    Last Post: 09-08-2008, 01:43 PM
  4. VIC: Ultra lows + Short shocks $100!!!!
    By PaRaDoX in forum Parts And Other Items For Sale
    Last Post: 27-10-2007, 11:08 PM
