Results 1 to 21 of 21
Like Tree6Likes
  • 1 Post By UFO
  • 3 Post By Xonar
  • 1 Post By greenacc
  • 1 Post By HEXEM
Thread: ve oil
    VE SV6, VX Executive II, VS Esteem
    Jun 2010
    Default ve oil
    Is it ok to use 10w-30 instead of 5w-30?? Any pros or cons for either??is
    2010 VE SV6 Ute and 2010 VE SSV Sedan
    Nov 2009
    I use 10w-30 in my 3.6L SIDI, no drama.
    Running a slightly different grade oil shouldn't have any impact on the motor.
    I believe it's more temperature related anyway, different oil grades for different environments.
    Ve r8 , VL turbo
    Oct 2011
    Camden
    05 VZ SV6 With VCM tune by CHE
    Mar 2009
    For Australia's climate you should be using a 10w or higher either way. A 5w is for temperatures much lower then we get here in Australia. Holden recommend a 5w-30 but you can easily use a 10w-30 and you should switch to a 10w-40 in summer when temps get above 35 degrees.
    2.5" Single catback, LSD with 3.46 diff gears, Mace Manifold spacer, K&N panel filter ,VCM Dyno tune, RDA slotted and dimpled rotors.
    More mods to come
    UFO's Avatar
    UFO
    UFO is offline I Believe
    MY10 VE Sportwagon SIDI 3L
    Oct 2009
    Quote Originally Posted by Dan24 View Post
    umm.... in what?
    your rides list a VX and a VS, but you're asking for VE?
    what engine?
    where are you located? (climate)
    what type of driving? (regular short trips or long ones)
    Jun 2010
    Quote Originally Posted by UFO View Post
    umm.... in what?
    what engine?
    Also have a VE thats why iv posted in this forum...
    3.6L Alloytec
    South east Melbourne
    Mostly short trips...
    Hope this helps, lost when it comes to oil
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    Either of those oils would be fine for short trips. Thinner oils in general ( such as the 5W-30) are better suited to short trips than long ones because your engine is running cold for a lot of the time so the thinner oil will flow better than a thicker one.
    Using a 5W-30 for long interstate trips would not be such a good idea because it can get too thin in Hot Aussie weather and not protect your engine properly. Also if thinner oils are left too long and start to break down the 30 ( hot viscosity ) drops even lower then you can really get into trouble.
    I use 5W-40 oil but it is more expensive.
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    The dealership Im at uses 10/30 for all the VEs so yes its fine.
    Silver Certified.
    VE SS auto
    Nov 2007
    Brisbane QLD
    e3 clubsport r8 m6
    Nov 2011
    from what i have researched 5w30 gives better protection on start up, the first number 5 relates to viscocity(thickness) when cold ie left over night while the second number 30 is the viscocity(thickness) while running at operating temp so 5w is better than 10w on starting car cold
    Commodore
    Jun 2004
    NSW
    Well oils sold in Australia are not API certified, so in all honesty...how the heck could you guarantee that 5w-30 for instance is that exact viscosity ? You'd hope so given that the bottle says it, but in reality lubricant industry in AU is not very well regulated. I use common sense.
    Stick with reputable brands and avoid marketing hype.
    I've been using shell helix oils for over 10 years in different cars and never had a problem.
    They don't burn, don't sludge, they keep the engine clean, and they are not overpriced
    In my VE 3.6 i'm using helix ultra 5w-30 and will stick to it for the next few years. Once the car clocks a few k's i will go slightly 'thicker' to helix ultra 5w-40
    In Australian climate you're better off with thicker oils, but not stupid thick. It's just not necessary and fuel consumption will increase. The engines these days are clearly different to what they were 10 yrs ago and tolerances are generally smaller and engine needs a good flowing oil....
    From my research and experience anything between 5-15w (cold) and 30-40 (operating temp) will be just fine to protect your engine.
    Most importantly service intervals recommended by Holden are very optimistic and in my opinion you'd have to be a fool to let your car run with the same oil for 12 months....
    Stick to a good oil and approx 7500 k's service interval regardless of time and your engine will be happy
    btw. when I contacted numerous dealerships in Sydney and inquired about oils NONE of them used 5w-30
    They all used either 10w-30 or 10w-40
    For them, I'd assume it's a cost cutting measure
    Hunter SS's Avatar
    Hunter SS is offline Growing Old Disgracefully
    2006 VE SS
    Mar 2009
    Upper Hunter Valley NSW
    My understanding was that the higher the viscosity number the thicker the oil. Would then not be the other way around? 30 weight the cold viscosity, and 5 weight the hot viscosity? I know they put full synthetic 5w-30 in my SS, but i am looking at putting thicker oil due to the temps and driving, the car is mostly driven on the highway. Plus it has 120k on the clock.
    On the other hand, my sons VR with 300k on it, gets 40w-70
    Reviled did i live as evil i did deliveR
    • UNDERSTEER is when you hit the wall with the front of the car.
    • OVERSTEER is when you hit the wall with the rear.
    • HORSEPOWER is how fast you hit the wall.
    • TORQUE is how far you take the wall with you.
    VE Calais V 6.0L
    Aug 2011
    The "w" after the first number represents the Winter rating.....
    As for Oils, everyone has a favourite brand and as long as the rating is close to what the manufacturer specifies, and oil changes are done frequently, then you should not have any dramas.
    For me, I have had a couple of bad mechanics work on my previous cars, so trust is a big issue for me.
    I do not trust the current lot of mechanics I have dealt with to put anything but the cheapest excuse for oil they can get their hands on.
    So I do it myself, and the money that I save on paying a mechanic to do it, I spend on the Oil.
    And because MY time is expensive (to me anyway), I am not going to waste my time trying to save a couple of bucks on semi par Oil, when I will be spending my valuable time doing the oil change.
    greenacc's Avatar
    VE Berlina
    Jul 2008
    Quote Originally Posted by Hunter SS View Post
    Good question Hunter, but not quite. Just to confuse things the 5 ( cold ) and 30,40,50...Hot are measured on different scales, so in fact the 40 is actually much thinner than the 5W even though its a bigger number.
  15. #15
    2012 S2 SV6 Sedan
    Apr 2010
    Quote Originally Posted by Xonar View Post
    helix ultra 5w-40
    This is whats going in my new engine next week - Shell Helix Ultra 5w40 Fully Syn
    Phil
    If your not living life on the edge, then your taking up space!
  16. #16
    ffestival is offline Banned
    Ford WB Festiva
    Nov 2011
    Darwin
    Commodore
    Jun 2004
    NSW
  18. #18
    Ford WB Festiva
    Nov 2011
    Darwin
    i was told to put it in my festiva because if you use 10w oils it will burn it
  19. #19
    Commodore
    Jun 2004
    NSW
    20w-50 would be as thick as I'd ever use
    The oils recommendations for Penrite meet nothing to do with your festiva
    "HPR 50 PREMIUM MINERAL
    SAE 40-70
    Premium Mineral and extra high viscosity petrol engine oil for use in older large six and eight cylinder engines especially
    those subjected to heavy/extreme load situations such as caravan/boat towing or in competition.
    Equally suitable for large capacity engines with severe oil consumption problems."
  20. #20
    VE CALAIS DEC 2007
    Sep 2005
    Pascoe Vale Vic
    Default ronaldw
    All engines with 195kw up use 5w-30 and all others 10w-30, all you have to do is look on the container and if it says GF4 then it is 5w-30 and GF-3 is 10w-30, if you follow that then the oil meets all industry specifications for those engines.
    I use holden oil 10w-30 which is a mineral oil and now they have the new 5w-30 which is a synthetic oil.
    I will be using 5w-30 next oil change GF-4 synthetic.
    Ronald
  21. #21
    VE
    Mar 2011
    n
    Quote Originally Posted by torana355 View Post
    Ummm... how many times a year do you change your oil?
    Sounds a touch excessive to me.
    HIDs.....LEDs..... DRLs..... CHEV Badges..... ->
